ATF flush
Old Aug 8, 2005 | 08:07 PM
B33p3r's Avatar
B33p3r
ATF flush
Hello all, new to this forum. Reading through some posts it seems to be very informative.I've read alot of posts concerning atf changes. Looking for some opinions.
98 Explorer XLT 5r55e tranny, 90,000 miles. Bought it used so I don't know about maintenance upkeep. Always noticed just before shifting down from O.D. it would run a little rough. Once it kicked down it would smooth right out. I've since got fluid changed at Jiffy Lube and I'm not too happy. I informed the Gentleman it specifically called out for Merc V. I was told no problem. So I assumed that's what I got. Well since then, a person in my carpool asked when it started riding rough(meaning the shift change above). He picked it out the first time he drove with me after the fluid change. He never noticed it before. It does seem a little rougher now. I also notice pulling the steep road outside my house it gets somewhat of a vibration while i'm into it pretty good. I never had that vibration before. Almost like driving over rumble strips but not quite that hard. Because of all this, I pulled the receipt out and found they used a Penzoil QS Multi Vehicle ATF. Is this supposed to be compatible? Does anyone feel the different fluid could be causing problems? Opinions please. I'm thinking about changing it myself right away just to make sure I have Merc V in it.
Old Aug 9, 2005 | 06:05 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 9, 2005 | 09:51 PM
98xlt's Avatar
98xlt
you'd have to research the penzzoil website, but I'd be surprized if its suitable for Mercon V application.
In the past, the fast lube places have only stocked a Mercon/Dexron III equivalent to which they would add a 10 or 12 oz additive per change that supposedly would make the mix "equivalent" to Mercon V. I did that once in a pinch but had the system flushed by Ford 1 year later. I did not notice any problems during that year. Its tough to find non-dealer places that stock actual Mercon V and won't lie to you about what they're really putting in there.
Old Aug 9, 2005 | 10:00 PM
triton_2002's Avatar
triton_2002
Take it back and demand a refund, then get it flushed with the correct fluid before you get any tranny damage.
Old Aug 10, 2005 | 06:12 AM
don96exp's Avatar
don96exp
Have a '96, started to chatter on downshifts, had the dealer do the trans flush, costs was $105 about 7 months ago. I understand Ford has an additive that keeps the clutched from hardening,whwich prevents chatter, for that trans, long story short the trans shifts great.
Old Aug 11, 2005 | 08:14 PM
B33p3r's Avatar
B33p3r
Thanks for the opinions. I'm definately getting the fluid replaced with Merc V. Probably try the flush routine myself. That way I'll know for sure. Thanks again.
Old Aug 12, 2005 | 06:14 AM
don96exp's Avatar
don96exp
Don't forget to get the additive for the trans from the dealer, it does make a difference.
kawika
49
Jun 23, 2021 11:47 PM
BAD RONALD
Jun 10, 2013 09:48 PM
Spool&Go
Nov 21, 2010 10:58 AM
bobthefarmer
Jul 30, 2005 08:19 PM
mandjknight
Apr 11, 2003 11:46 AM
