Sponsored by: Real Truck
hitch haul platform
Old Aug 8, 2005 | 07:55 PM
LUMBERMAN's Avatar
LUMBERMAN
hitch haul platform
I was in PA. over the weekend and I bought a hitch-haul cargo platform that plugs into my 2" receiver, after I assembeled it I pluged it in and it was wobbely as hell, so I returned it, has anyone had this problem? Thanks
Old Aug 8, 2005 | 08:00 PM
2000silverbullet's Avatar
2000silverbullet
I've seen those before and noticed that guys had tie downs on the cargo and the platform to hold everything steady back there.
Old Aug 8, 2005 | 08:19 PM
BFR250SD's Avatar
BFR250SD
Mine was the same way. Just the way some of them are. I used the snot out it and never had any real problems other than it being a little wobbley. Some of the new ones have the J pins. Haven't tried those, but seems like it would work.
Old Aug 8, 2005 | 10:47 PM
jake00's Avatar
jake00
i'll bet its a quality issue, I have a cheap bike rack that wobbles, and an expensive one that does not.
Old Aug 9, 2005 | 11:06 AM
toypuller's Avatar
toypuller
You need an "anti-rattle" bracket for your hitch. They cost $10-15 and mount on the metal bar that inserts in the hitch. You then screw the bolt and nut until it's tight.
It will also keep a normal hitch from banging around when there is no weight on it.
Look at Cabela's or any trailer supply store.
Old Aug 9, 2005 | 02:28 PM
CmprSpecial's Avatar
CmprSpecial
I think this is what he is talking about Anti-Rattle Bracket If that doesn't work, search for item IF-520365 at www.cabelas.com
Old Aug 9, 2005 | 03:21 PM
BFR250SD's Avatar
BFR250SD
Oh, it's not just rattle, like your ball mount does unloaded. It has quite a bit of movement to it. At each end of the rack it will go up and down about 1 - 1 1/2 inches.
