PCM Reprogramming
Old Aug 8, 2005 | 07:41 PM
juventus's Avatar
juventus
PCM Reprogramming
I had some hard upshift problems on my 2002 Explorer. I brought it in for service and they found that the all the shift solenoids were not working correctly so they were changed.
I also had intermittent problems with delayed engagement of reverse. To address this issue, the powertrain control module (PCM) was re-programmed.
I have an extended warranty (EasyCare) which covered the shift solenoid re and re.....but they did NOT cover re-programming of the PCM.
My questions: Would the solenoid replacement work have required a PCM re-program anyway? If re-programming the PCM was necessary to address a problem, why wouldn't the extended warranty cover it?
Thanks...
forensicpsyguy
Nov 24, 2019 02:59 PM
Twinsdad98
2004 - 2008 F150
Apr 9, 2017 01:07 PM
AmtrakDriver
6.4L Power Stroke Diesel
Feb 13, 2011 06:11 PM
forensicpsyguy
Feb 14, 2010 03:38 PM
SeannyBoy84
Computer Chips & Tuners
Oct 17, 2005 05:29 PM
