Power antenna Question
Old Aug 8, 2005 | 07:33 PM
learpilot's Avatar
learpilot
Has anyone installed a power antenna in the stock (56) location on the drivers cowl? Any suggestions? Thanks
Old Aug 8, 2005 | 09:19 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
I recently completed an installation of a power antenna on the RH cowl, but my location is a couple inches forward of the stock location. The previous owner had one of those short rubber antennas that was bent over from being whacked by the opening hood. The new one I installed actually came from JC Whitney's a few years ago and i had to modify the base to match the outer cowl surface. I started with an old black plastic shift **** and turned it down slightly smaller and smoothed the surface with 500 and 1000 grit sand paper. To match the contour, I used 60 and 240 grit disc's on an angle die grinder. It ended up fitting so snug that I did not need a rubber gasket. When the antenna is retracted it sticks up about 2 inches. It will be wired into the radio to extend when power goes to the radio. Sorry it is not in my gallery yet. I owe the gallery an update after several months of assembly.
Old Aug 8, 2005 | 10:58 PM
WillyB's Avatar
WillyB
Ranger, what is going to happen if the hood is up and someone turns on the radio? Or if the radio is already on, and someone (you) turns the key on?
Old Aug 9, 2005 | 08:17 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Good point *****. I am now considering a simple toggle switch mounted inside the 3" deep glove box (Vintage Air) that would interrupt power to the antenna motor. That would be another safety feature along with having only one ignition key.
Old Aug 9, 2005 | 08:37 AM
theGman's Avatar
theGman
I have a power antenna in my 55 panel stock location. One wierd problem with it is that my new Vintage Air kit hits the inside guts of the unit, and will surely rattle when I get the truck back on the road. Small point, but worth remembering. I know you asked about a 56, and the 56 hole is in a different relative location, but I thought I'd mention it anyway, for what it's worth.
Old Aug 9, 2005 | 09:31 AM
fatfenders56's Avatar
fatfenders56
for anyone who may be interested, there is a very good inside mounted antenna available from Dakota Digital. They work very well and are totally out of sight, in more ways than one.
Old Aug 9, 2005 | 09:42 AM
Randy Jack's Avatar
Randy Jack
FF56 -
Thanks. I wanted to know who sold those inside antennas.
For anyone else who's interested, here's the link:
http://www.dakotadigital.com/index.c...rod/prd105.htm
Old Aug 9, 2005 | 09:47 AM
fatfenders56
they work great, I have one in my 31 Vic
Old Aug 9, 2005 | 09:48 AM
learpilot's Avatar
learpilot
My plan is to have the forward tilt hood so hitting the antenna should not be a problem. However one that is totally hiddden may be a better choice. Thanks guys
