Sponsored by: Auxito
Window sticker
Old Aug 8, 2005 | 01:08 PM
tpferro's Avatar
tpferro
1999 F150 Supercab with rear window slider. Just like most of what I've read in this forum, mine leaks into the headliner on the passenger side and drips onto the back of the seat. On the outside of the cab, I've looked through the space between the cab body and the window frame, and I can see a gasket that is completely detached and loose.
How do you remove the window?
Old Aug 8, 2005 | 05:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 8, 2005 | 05:57 PM
Mnf350's Avatar
Mnf350
You have to take the trim off the inside and there are nuts holding the window in. You will need 5/16 butyl tape to reseal it.
Old Aug 13, 2005 | 05:34 AM
1%-2%-vanner's Avatar
1%-2%-vanner
i have a '99 Lariad with leaky slider window, went to a glass place and was shown were window frame was cracked, used plastic frames up to '99 replaced with medal after that, about $225 to replace
