77 351W timing
Old Aug 8, 2005 | 01:02 PM
fmc400's Avatar
fmc400
MSEE
77 351W timing
I'm confused. The emissions sticker calls for 4 degrees BTDC with the vacuum advance plugged, but my vacuum advance uses manifold vacuum. I thought they were always supposed to run off ported vacuum, but the setup appears stock and I'll leave it be. Do I set the timing at 4, or back it off a couple degrees since the timing would be way past 4 at idle with that manifold vacuum advance?
By the way, I can't rotate the distributor once I've loosened the bolt...I'd appreciate it if anyone could give me some fast tips on freeing it.
