Batteries
Old Aug 8, 2005 | 03:58 AM
Tricks's Avatar
Tricks
Batteries
Help! Does any one know if you can jump start or charge a battery in a 350 Diesel truck
Old Aug 8, 2005 | 05:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Must read if you own a 6.0
https://www.ford-trucks.com/forums/s...d.php?t=325000
See you on the boards.
Enjoy FTE …..
Moved and member notified
Old Aug 8, 2005 | 07:17 AM
Maxium4x4's Avatar
Maxium4x4
Sounds like a Trick question to me.
Answer: Yes
Just like any other 12 volt system. If you have the torq-shift trans and disconnect or drain the battery the transmission must relearn its shift strategy. In your operators manual it said to turn off all electrical items and set the fan switch to high in case of an electrical surge.
