Intermitent wiper switch.
Old Sep 30, 2002 | 08:44 PM
starweb's Avatar
starweb
I have a 79 F150 with delay wipers and a 79 F100 without. will the F150 switch swap out to my F100?
Old Sep 30, 2002 | 08:53 PM
78f250lj's Avatar
78f250lj
Yes it will.
Old Sep 30, 2002 | 09:28 PM
starweb's Avatar
starweb
even if the wipers on the F100 are not intermittent?
you are saying that it will just plug in and work right?
Old Sep 30, 2002 | 09:48 PM
78f250lj's Avatar
78f250lj
To convert from non Intermitent to Intermitent, you need the Intermitent switch and the Intermitent black control box and you plug it into your existing wiring.
Old Oct 1, 2002 | 01:26 AM
starweb's Avatar
starweb
ok, so, I called the dealership and they said it would be $60.00 for the switch. does the black box come with it. if so, can you give me instructions on how to install!!
Old Oct 1, 2002 | 03:40 AM
f10074's Avatar
f10074
Check the tech articles, near the bottom. There is a write up on it.
-- William (Tony) Whited
74 F350 Ranger XLT Super Camper Special 460
77 F150 Custom 460
Okinawa, Japan Semper Fi
Old Oct 1, 2002 | 06:13 AM
bentkey's Avatar
bentkey
My 1978 f150 doesn't have the intermitent wiper switch either. Can someone explain why the wipers don't return to the bottom of the windsheld when I turn them off? Have changed the switch but it didn't fix the problem.
Old Oct 1, 2002 | 06:23 AM
JimmyK1957's Avatar
JimmyK1957
Wipers not parking could be a bad ground at the wiper motor. Try using a jumper wire from the wiper motor to a good ground. If they park ok, then a bad ground is the problem.
Old Oct 1, 2002 | 11:08 AM
Mil1ion's Avatar
Mil1ion
No the governor doesn't come with it.
That's just for the switch.
The last Ford price for the governor I have, was $185.00.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Oct 5, 2002 | 07:45 PM
starweb's Avatar
starweb
ok, so I see someone on Ebay has the whole package for sale. does anyone have this for sale? If not I am going to bid on the one on Ebay
thanx
Old Oct 5, 2002 | 08:09 PM
66 Ranger's Avatar
66 Ranger
There seems to be a complet unit for sale on ebay most of the time. I bought one and, it works fine, for about 40 bucks.
Old Oct 6, 2002 | 04:46 AM
Torque1st's Avatar
Torque1st
Posting Legend
You can find them in the scrap yard. I believe the same system was used in the vans and other fullsize vehicles.
Old Oct 6, 2002 | 10:09 AM
Ford79's Avatar
Ford79
Yep, I found mine in a scrap yard. Picked it up for $5.00. Everything works great.
Old Oct 6, 2002 | 10:10 AM
hawkrod's Avatar
hawkrod
the intermittent wipers are a truck only item. the cars and vans use a similar but different set up. the truck unit is neat because it evolved from a mustang/torino unit (early ones have torino switches still, lots of money to the torino guys!) but have a much better govenor. the car and van units mostly use a slide switch rather than a rotary switch and fords with slide switches have different plug assemblies and won't interchange. the rotary style can be retrofitted to any ford with a rotary switch like old mustangs and i even put one in my 65 ford econoline pick up! (to put it in the econoline you have to use a 66 or 67 wiper motor though). the truck unit is pretty much the same all the way up to the late 80's but i am told there is one less connector for the washers (have not checked yet) but it works fine by moving one wire. hawkrod
Old Oct 6, 2002 | 10:12 AM
Supercab's Avatar
Supercab
Any mid-late 70s Ford car or truck with a dash mounted switch will swap into '67-'79 Ford trucks for what I've heard.
