oil pan
Old Oct 17, 2002 | 06:41 PM
snow991025's Avatar
snow991025
Post oil pan
I have a 79 ford f150 and I need to change the oil pump. I have disconected the bolts to the oil pan and nocked it loose, but there's not enough clearance to pull it out. Wonderingif anyone knows a way to get it out. Easy way if possible. Thanks
Old Oct 17, 2002 | 07:26 PM
73Highboy's Avatar
73Highboy
oil pan
Well, if you have a front sump pan, this may help if suspension/axle is blocking it. Jack up your truck by the body/frame, so your axle/suspension is suspended completely, maybe then you can get it out. Rear sump pans come in handy in times like those.
Old Oct 17, 2002 | 07:30 PM
joetee10's Avatar
joetee10
oil pan
I recently took on the same project, and i found by taking loose the engine mount bolts on the frame, you can jack up the engine enough to remone the oil pan. Once the engine is jacked up you will have to partially drop the pan and disconnect the oil pump and the strainer assembly. Then the pan can be slid out the back or the front depending on whick pan you have. You may have to turn the crankshaft to provide the necessary clearance. I cannot swear that this will be successful, since my engine has a double sump oil pan, but i thought i'd make the suggestion any way. Good luck!!! Let me know if I am of any help, e-mail me at joetee10(No Email Addresses In Posts!)
Old Oct 17, 2002 | 07:52 PM
78bigunns's Avatar
78bigunns
oil pan
[updated:LAST EDITED ON 17-Oct-02 AT 08:53 PM (EST)]Not sure whether I have a single or double sump pan, I just did mine while back, had to loosen mounts, took a block of wood and a floor jack, boosted the motor up a little. And I had to pull the pump. The pan silde out fairly easy. My oil pan is deeper in the rear side I believe. Next time I'd like to try using a lift to pull the motor up. Good luck, Blair
Old Oct 17, 2002 | 09:32 PM
snow991025's Avatar
snow991025
Post oil pan
Thanks everyone! I don't know if i have a frount sump or rear sump. The pan is deeper in the frount then the back. It's only like a half inch from coming out the frount. I'll go try some of these things and see if it works. Any more help would be great. Thanks
Old Oct 18, 2002 | 07:28 PM
snow991025's Avatar
snow991025
Post oil pan
K I got it out bearly by dropping the pump in the pan and it cleared the radiator bearly, but i don't know how i get it back in. Any ideas? The pump is bad that's why i'm changing it. It had really low oil pressure. I found little cunks of plastic in the pan and screen. Doe's anyone know what that is i didn't think any plastic was in the engine. Any help would be great! Thanks
Old Oct 20, 2002 | 03:15 AM
429fordf250's Avatar
429fordf250
oil pan
the plastic is from the timing chain the cam gear from the factory is plastic coated and it comes off over time it is about that time before it fails
Old Oct 20, 2002 | 08:27 AM
Quadiquizm's Avatar
Quadiquizm
oil pan
