Propane/gas?
Old Oct 8, 2002 | 10:21 PM
daddyswheels's Avatar
daddyswheels
Propane/gas?
I know a guy who worked for the gas utility co-kind of a tinkerer, very qualified- well he did and add on to his Crown Vic that let him run gasoline or propane or blend-does this sound right to anybody out there? I know you need bronze valve guides, what else before the rig can work on an engine--I like the idea of propane cruising on long hauls if it would be feasable--I know the fuel tanks are HEAVY--where's our expert on this?
Old Oct 9, 2002 | 12:34 AM
heathdaily's Avatar
heathdaily
Propane/gas?
No expert here.
But I did run this set-up. It's not even hard to obtain. Probably the easiest place to get one would be J.C. Whitney. There's a regulator you'd bolt to your fender and a unit that sets above the carb. When propane is in use you pull a cable(like a choke cable) and it drops down onto the carb. Gas and propane flow is controlled by solenoids so you aren't using both at once. This is all sorta old-tech so there's plenty of info available and reputable companies to deal with. Used units sell for approx. 100 dollars around here without the tank. I THINK you can get a new one for around 200-250 dollars, but I'm not sure. The only downside I ever found was that with everything sitting on top of the carb it's darned hard to put out a carb fire. Then again if you aren't shooting ether into the element like an idiot, you shouldn't have that problem.
You will suffer a slight power loss on propane. But that can easily be overcome with higher compression. Propane has 105 octane rating. Doing that however will ruin your gas capability(unless you've got 105 gas).
Other mods to consider, good valves and propane hardened seats(like seat inserts for pre-hardened heads only harder. Propane has NO lubricating qualities.
I'm sure someone else will have more to add. Goodluck.
Old Oct 18, 2002 | 11:16 PM
masterbeavis's Avatar
masterbeavis
Propane/gas?
Old Oct 20, 2002 | 11:33 AM
jerry p's Avatar
jerry p
Post Propane/gas?
I have used straight propane set ups and "dual fuel" set ups. They work fine if set up properly.Alot depends on your propane source! e-mail if you want more info. Jerry P scheernj@mtcnet.net
Old Oct 20, 2002 | 04:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
Propane/gas?
You might want to check the Fuel forum for info.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
send email/pm if you need a reply -Thanks![/font]
