Sponsored by: Real Truck
How to remove Overdrive Switch?
Old Aug 7, 2005 | 03:32 PM
Hi-psi's Avatar
Hi-psi
Guys,
When I bought my truck it had the common problem of the OD switch not working. Just got around to pulling it apart today to find my broken wires. Now here's the problem. The wires broke so close to where they go into the shifter shaft that there's no way I'll be able to splice them. So I thought, no biggie, I'll just pull the end of the handle/switch off and splice them and run new wires down the shaft. How in the heII do you get the switch off? I've tried twisting, pulling, prying with a flathead in the little slot on the back side. I can't get this thing to even budge. I'm sure it's something I'm just missing, but I can't get it off. Thanks in advance.
Old Aug 7, 2005 | 04:21 PM
Hi-psi's Avatar
Hi-psi
C'mon guys... Anyone?? I have the whole thing torn apart right now.
Old Aug 7, 2005 | 04:27 PM
wlihntr's Avatar
wlihntr
on my truck the end cap around the button just pops off, in fact if i grab the end wrong it will come off when i shift out of park. i have already replaced it once it was like $5.00 at the dealer
Old Aug 7, 2005 | 04:29 PM
Hi-psi's Avatar
Hi-psi
I have the shifter handle completely removed from the truck and sitting on my kitchen table. I've tried pulling, prying, twisting every way I can think of and I can't get the end/switch off. Maybe the previous owner glued it on?!!??
Old Aug 8, 2005 | 11:41 AM
Lifted Sky High's Avatar
Lifted Sky High
Wouldnt surprise me. I had to glue mine on after it kept falling on the floor.
Old Aug 8, 2005 | 11:46 AM
Hi-psi's Avatar
Hi-psi
Ended up just beating, wedging, and prying the ***** out of it. Finally it came off. Used some thin wire to splice near the switch, then fed it back into the shaft. Connected the new wires to the existing ones on the column and she's all back together now and working perfect.
DDPJ
Oct 4, 2014 06:51 AM
RangerDude17
Jan 25, 2014 04:38 PM
Jimmyrig
Oct 31, 2013 10:46 AM
pin8246
Jun 3, 2013 02:01 AM
2muchgrass
Apr 14, 2013 02:31 PM
