After reading through the postings i thought i might have short in UVC wires.
I have ohm out the 9pins on each VC gasket to find .8 ohms on all eight GPs and ~3.3 to 3.4 ohms on the injectors. There is no continuity to ground on the 5 middle injectors pins and no continuity to GP pins (outer 4) on either bank. ... Did not see any problems.
Is it correct when the CPS goes bad it is just bad ... no gradual two day type deterioration. My engine idled fine would not increase rpm without jumping. It only hesitated/hickuped under load (pulling hill) absolutely no power .... next day could hardly pull it out of drive ..idling was getting worse ...replaced fuel filter checked IPR o-rings .... now it want even start ... sounds like it is trying to fire up ... just jerks around. There is no SES light. Ive tried to pull pending codes .. there are none.
Could it be the MAP sensor?
Could it be the innercooler boots loose?
What other things can i check before i have take to the very expensive DR/Dealer?
It's unlikely that the MAP could cause it, and impossible for loose boots.
Try starting it with the ICP (injection control pressure) sensor unplugged. That's the three wire plug on the inside of the drivers side head. You were right next to it when you had the IPR apart.
Unplugging my ICP did not change anything .... it sounds and smells like if may have fired .... still wont start .... I do not smell any raw diesel in exhaust .... Can a fuel pump gradually go bad over a two day period? I feel like it is my fuel pump or my HPOP?
I might be wrong here, but , the tach usually wont indicate during cranking if the cps is bad. Also check for oil in valley pan for leakage from HPOP, if that isnt full, it wont run right. Fuel supply pump might also be the culprit. I suppose you could open the fuel filter cap and see if fuel runs into the bowl with the key on. I dont profess to be a wizard but there's where i'd look. Hope it helps you out.
Have you checked all your fuses? If your fuel heater has shorted out and blown the fuse the PCM power will be cut. Can't remember exactly which fuse, but it'll be one of the maxi-fuses under the hood.
Yes, I have checked all fuses, the only one i had blown was for my cig lighter and ODB ... found that one when i tried my actron. I replaced the idm Relay thinking that might be th problem .... but now im leaning towrds the fuel pump. Do the relays go bad .... wouldn't there be a SES light?
where is the reservoir for the HPOP located? How full is it supposed to be?
Right in front of the HPOP. It's the skinny rectangle box on the top front of the engine. Pull the allen head plug on the top drivers side of the reservoir, the fill level should be within 1/4" of the top.
Is the fuel pump running? It should cycle on for 20 seconds with the key on. If it's running at all the engine should start....it only needs to make about 20psi for ignition, then maintain 50psi or so for normal operation.
I turned the key on (not starting position) ... i put my hand on the fuel pump and could not feel any vibration ... how can i tell if it is working? does it make a noise?
New info .... i checked the wires to fuel pump didn't see any shorts ... i knocked on it a couple of times ... now when i turn the iginition on it makes a vibration and some gurgling noises ...The engine started this time ... but would not idle well.
Sounds like i need a new fuel pump ... I will test the psi also.
Is there any rebuild kits for the fuel pump? How much is a new fuel pump? Where is a good place to get one?
Like everyone ... i need to save $$$$$$ where i can ...
You found your problem. No rebuild kits available. Sealed unit. As far as where to buy, used is the least expensive from a junkyard. You assume the risk on how long it will last. Or new for $244.67 at fordparts.com. Ebay??? Craigslist???
Autozone carries a Master pump for $179, but they don't generally stock it, so it'll take a day or two to get it. I got mine from Napa for $256 largely because it's a better Federal-Mogul pump and it was in stock same day. I don't know who would carry the factory Bosch pump aside from the dealer, but they wanted $331, and had to order it.
Still not one hundred percent sure that this is my whole problem .... Can someone please make me feel certain that my fuel pump is the sole cause. Here is why ...
I took a wrench and tapped on the fuel pump pretty hard. The truck starts and idles fine now ...Back to orignal problem when pressing pedal the rpms go up but is somehwat hesitant ... kind of like a miss ... but when i reach above 1000 rpm it smoothes out and will stay smooth all the way to 2000 rpm doesn't even hesitate at all. Just in the transition of increasing rpms. i noticed at 1000 rpm the stick is jumping around about 1/4 inch. I will of course replace the fuel pump ... i just want to know if i need to keep my Dr.s Appointment with the dealer shop. It is set for thursday because they are a week behind.
If your fuel pump required a smart spanking with a wrench, it needs to be replaced. No question there. I'm guessing that now that it's running it's only making just enough to give a very poor fuel supply to the engine, hence the driveability issues. Replace the pump and take it from there.
