1978 - 1996 Big Bronco
TFI module bolt size?
Old Aug 6, 2005 | 06:09 PM
lattices2's Avatar
lattices2
'90 Bronco, 351 EFI
This sounds real simple but Im having a hell of a time trying to change my TFI module. I did the test according to Haynes and its defective. At least ill change it and find out.
Ive tried 3,4,5,6mm sockets and the almost equivalent SAE sockets on the 2 bolts. I got a mirror and they are hex bolts on there. I heard once theres a special tool for it.
Ive seeked help at autoparts stores(was told its a hard to get 5.5mm deep socket), ford dealership(useless a&$%*$)...
I tried the 7/32" socket which is 5.56mm and didtn work either.
PLease help soon.
Thanks.
Old Aug 6, 2005 | 06:17 PM
94 XLT White/ Silver 302's Avatar
You have to buy a special tool at the auto parts, to remove the TFI. I bought mine from Auto Zone it's under $10.00
Old Aug 6, 2005 | 06:21 PM
lattices2's Avatar
lattices2
thanks
Thanks
Ill try again tomorrow.
Old Aug 7, 2005 | 12:50 AM
jaja's Avatar
jaja
i'm potentially having the same problem.... what year was this tfi module on the 5.8? btw mine is a '94.
Old Aug 7, 2005 | 07:47 AM
lattices2's Avatar
lattices2
moduel
Its a 1990 351 EFI Bronco. I believe its still the stock TFI module.
It says Mastercraft. Ive been having erractic problems starting, and its cut out on me a few times while driving.
Old Aug 8, 2005 | 08:32 AM
lattices2's Avatar
lattices2
i changed the TFI module. Went to 3 autoparts store and the dealer to ask about the socket for removing it. None of them knew about it and said just use a socket. So i went to the autoparts store again and saw 3 of them on the shelf labelled. FORD IGNITION MODULE TOOL. $7.95
Any other othen deep sockets dont work. I tried them all.
Thanks. Runs much better. Starts right away and doesnt stall. Now just need new exhaust
Old Aug 8, 2005 | 06:53 PM
I would keep that TFI tool in your glove box, you never where you'll be when you need it again.
Old Aug 10, 2005 | 11:19 AM
cap4004's Avatar
cap4004
I was not able to use the special TFI socket on my truck. I used a 5.5mm deep well socket, 1/4"-drive. It worked perfectly. (I had to buy a lot of sockets to figure out 5.5mm!) Anyway, AutoZone had the 5.5mm socket in stock.
Old Aug 10, 2005 | 11:54 AM
lattices2's Avatar
lattices2
socket
I tried the 5.5mm deep socket but it wouldnt fit in the hole Maybe a thinner one would of but i got tired trying to find one.
Old Aug 10, 2005 | 02:18 PM
jaja's Avatar
jaja
just cough up the $7 to take that screw out... maybe replace it with a phillips or something. Make life easier in the long run.
Old Aug 10, 2005 | 09:02 PM
scoutpup99's Avatar
scoutpup99
I used the 1/4 inch drive deep 7/32 laser etched Craftsman socket to remove mine. I had to tap on the end of the socket with the rachet on a Taurus. i have used that socket on a taurus, my 89 dually, 90 ford ranger and my 92 Bronco.
Daniel Pennington
Old Aug 11, 2005 | 01:34 AM
jaja's Avatar
jaja
scout - i used the same deep socket too... i got one of them out, but the other was off center so I had to borrow the tool.
Old Aug 11, 2005 | 12:53 PM
HMA-169's Avatar
HMA-169
The same bolt head is used for the coil. I keep the fancy little tool with me.
Mikemakeswine
Sep 10, 2014 08:01 AM
6922
Feb 11, 2012 04:28 PM
Supercrewzin01
Aug 10, 2009 05:38 PM
gemmBronco
May 27, 2006 08:28 PM
jaycrow
1983 - 2012 Ranger & B-Series
Aug 31, 2003 08:57 PM
