Power Window Probs. in TWO trucks!
Old Aug 6, 2005 | 04:49 AM
1990F2504604x4's Avatar
1990F2504604x4
Exclamation Power Window Probs. in TWO trucks!
Ok, forgive me if this has already been covered recently but it is 2:45 AM here, On my '90 Reg Cab XLT Lariat the driver side PW quit while it was down, not even a motor sound at all, we took the door panel apart at work and hit the motor and it moved in spurts until it was up. Now how hard is it to replace the gears and motor, the motor is riveted in.
Second on my '89 SCAB XLT Lariat I noticed last week that there was a fairly deep gouge/score on the outside of the glass that is slowly getting deeper, what is causing this and how hard is this piece of glass to find?
Thank you guys in advance for everything!
P.S. Thank God for wing windows and A/C.
Old Aug 6, 2005 | 01:49 PM
muletrane's Avatar
muletrane
I just repaced the passenger side motor in my 90. It was a real pain in the ***. I got the motor for $35 at a junkyard. I think that you could probably get a window pretty cheap, too. I swear that Ford put in the motor then put the inner and outer door skins together. There is one screw in the middle that I needed tin snips and my girlfriend's small hands to get to. I can't imagine it being less than a 2 person job. I hope you have an afternoon of spare time and a lot of beer for when you're done.
To tell you the truth, after replacing that motor I filed the job under "things I'll never do again".
Bob
Old Aug 6, 2005 | 03:19 PM
90xlt4x4's Avatar
90xlt4x4
Just drill out the 3 indentions with a large drill bit and use a nut driver to remove the screws. After doing one, I finished the other side in about 20 minutes. Check the 3 plastic plugs inside the motor before buying a new one;my window did the same thing and it was only the $5.99 plugs. You can find em in the help section at autozone; called window regulator plugs.
Old Aug 6, 2005 | 03:47 PM
guzzler96's Avatar
guzzler96
Thumbs up
90xlt4x4 is right on the money with this one. There are numerous posts on here about this and all with basically the same info. I have done both of my motors and they work fine.
Old Aug 6, 2005 | 06:50 PM
1990F2504604x4
Thanks for those ideas, any for the weird etching going on in my '89?
Old Aug 6, 2005 | 06:54 PM
Popa Tim's Avatar
Popa Tim
Alot of times that is dirt/stones lodged in the window seal.
Old Aug 6, 2005 | 07:00 PM
1990F2504604x4
Angry
Ok, are the door panels from JC whitney any good? My 90 has some broken plastic pieces now , and as an update the motor is FRIED, went to move the window up more before it rains because it sagged down and some smoke came up from the gap between the door and panel and all sounds of the motor are now gone, the volt gauge doesn't even register a drain now. I hope the harness did not fry.
