351/460 which PS pump??
Old Aug 6, 2005 | 01:09 AM
Doc1's Avatar
Doc1
351/460 swap in 81 F250 4X4 which PS pump??
Which PS pump is required when doing the 351/460 conversion in a 81 F250 4X4. I have one out of a 76, but there are clearance issues.. Thanx in advance.
Last edited by Doc1; Aug 6, 2005 at 01:20 AM. Reason: Missed a few words in the heading
Old Aug 7, 2005 | 06:50 PM
8 Lugs's Avatar
8 Lugs
The plastic bodied pump with the 2 belt pulley!
Your best bet when doing this swap is to raid all the pulleys and bracketry (if that's a word) from an 83 up till serpentine belt 460.
I have done a handfull of these "460 injections" and found this to be the easiest way out, however, good luck finding a doner!
Make sure you use double belt pulleys for the water pump, power steering set-up or else it WILL squeel!
Steve G.
Old Aug 7, 2005 | 08:26 PM
Doc1's Avatar
Doc1
Thanx for the info, I got it up and running.. Now I'm having big clutch issues..
Old Aug 7, 2005 | 09:50 PM
Steve's Beast's Avatar
Steve's Beast
Post
Well Tell us your clutch issues, I may be able to help. I just did the same conversion. 81 F250 W/351M 4X4 Now with a 460 and 5sp Zf.
What did you get your 460 out of?? I am just curious!
Old Aug 7, 2005 | 09:54 PM
fordborn's Avatar
fordborn
The thread on the clutch issues he has is here https://www.ford-trucks.com/forums/s...d.php?t=400154 check it out and see if you can help.
Thanks
Old Aug 7, 2005 | 09:58 PM
Steve's Beast
Thanks! I Guess I should have searched it before poasting! Whoops! I will keep it in mind for next time!
Old Aug 8, 2005 | 12:05 AM
Doc1's Avatar
Doc1
The problem I'm having is the disk won't dissengage, I've used the 460 flywheel, 460 clutch assy, with the 351 bellhousing and clutch fork.. I got the motor from a 76 F250, then went 0.30 over with some other goodies.. But I'm stumped on the clutch deal. Is the 460 flywheel suppose to be stepped??
