Modular V10 (6.8l)
is this normal?
Old Aug 5, 2005 | 09:30 AM
akers4000's Avatar
akers4000
is this normal?
i have 06 cc dually v10. when towing my 10.000 k trailer engine will start to skip slightly at high rpm under hard acceleration especially on hilly back roads.
doesnt do it when on highway.almost like its starving for fuel. i towed twice
at 300 miles and at 700 miles. so it shouldnt be filters or such. it pulls hard
to a point then starts this skip or loss of power?
Old Aug 5, 2005 | 10:01 AM
Casey's Avatar
Casey
At what RPM does it do this?
Old Aug 5, 2005 | 10:51 AM
akers4000's Avatar
akers4000
around 4500, 4700 rpm
Old Aug 5, 2005 | 11:46 AM
Casey's Avatar
Casey
That's too low RPM for what I was thinking. There is a rev limiter, but it's set at about 5300 RPM. I don't have any other ideas, except take it back to the dealer.
Old Aug 5, 2005 | 12:31 PM
ken04's Avatar
ken04
plugged or partially plugged fuel filter, or a bad coil would be my first 2 guesses. It should do this obviously, even new gas tanks can have gunk in them which can clog a new filter. But the coil on plug is probably the culprit especially a high speed miss, good luck, nice truck ! Ken
Old Aug 5, 2005 | 10:40 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, probably a bad coil, get it back to the dealer forthwith!
If you can get it to "skip", and without shutting it off, bring it to the dealer and have it scanned (again, without shutting it off), they can pinpoint the cylinder #.
art k.
Old Aug 6, 2005 | 06:18 AM
akers4000's Avatar
akers4000
not exactly sure at what rpm. i didnt take not of that. maybe it was speed
limiter. truck runs good otherwise.
Old Aug 6, 2005 | 11:19 PM
nisiar's Avatar
nisiar
If the road surface is uneven, and you're moving at a goodly rate, you might be feeling the LSD working as the rear wheels load and unload over the undulations.
