Disk brake conversion
Old Aug 4, 2005 | 09:30 PM
WillyB's Avatar
WillyB
I have been looking over the solid front axle of my 59 - has anyone ever changed the spindle at the king pin for one with disk brakes? Sure would be an easy mod!
Old Aug 5, 2005 | 12:29 AM
imlowr2's Avatar
imlowr2
What spindle would fit right on that has disc brakes on it? I don't know what vehicles had disc brakes on them with a straight axle front end. The other thing to be concerned with is the diameter of the king pins and will the spindles bolt right up?. I just completed the disc conversion kit from CPP. It wasn't much more difficult than pulling the whole the spindles off. It's actually a pretty cool kit and works really nice.
Old Aug 5, 2005 | 01:11 AM
WillyB's Avatar
WillyB
No straight axle had disks, to my knowledge. but what is the difference between a straight axle and a twin I beam - from the king pins out? Changing the spindles is a good mod for the 66 to 72 drum to disk conversion, why wouldn't it also work on a straight axle, assuming the king pins are the same size, or can be machined to the same size?
Seems simple, but if it was that easy someone would have already done it. What am I missing?
Old Aug 5, 2005 | 02:55 PM
imlowr2's Avatar
imlowr2
*****, good question. I don't have the answer to that one and I'm not sure on the Twin I beam spindles as to the compatiblity of the straight axle front. Your right, if it was that easy to convert, people would of already been installing them. You got my curiousity going on this one.
Old Aug 5, 2005 | 10:26 PM
51dueller's Avatar
51dueller
The Twin I beam spindles have no way to hook up your stock draglink.
Old Aug 5, 2005 | 11:07 PM
Col Flashman's Avatar
Col Flashman
John's F-Funhundred in Anaheim, CA. sells a straight Bolt-On Disk Brake Conversion Kit to do just that.
Old Aug 12, 2005 | 08:10 PM
51frrdtrk's Avatar
51frrdtrk
Master Power brakes sells a kit to convert the straight axle to disc. They have two kits. One uses the 5X5-1/2 bolt center on the original hubs or you can convert to the later configuration of 5X4-1/2 or 5X4-3/4 bolt center. 704-664-8866
Old Nov 19, 2005 | 11:07 AM
dmctwo's Avatar
dmctwo
The site below offers a bolt on kit for disc brakes with a variety of bolt patterns. One of the best features I think is that it uses readily available off the shelf parts.
So far no one makes a kit for me yet, because no one makes an 8 lug conversion kit
Dennis
http://ecihotrodbrakes.com/early_for...nversions.html
Old Nov 19, 2005 | 03:51 PM
dmctwo's Avatar
dmctwo
I posted this in a couple other spots but it's applicable here too
Dennis
I found a place in CT that makes two piece adaptors that can convert the number of lug nuts. Has anyone ever thought about this as an option? The minimum thickness it 1.75 inches, but could be more due to the size of the bolt patterns involved. I have an inquiry to them, but probably won't hear from them until Monday at the earliest.
Just thought I would ask the gurus here what they thought.
Dennis
http://www.skulte.com
Old Nov 21, 2005 | 09:41 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I used teh ECI kit on my 49. Quick and easy!. I bought the basic kit as I already had the calipers. The basic kit comes with the bracket, bolts, and bearing adapters. Here's the part that might stop some of the purists, the kits requires GM calipers and outer bearings.
Basically you use late 70's to early 80's ford 1/2 ton rotors, inner bearings and seals, and dust cap
GM big car calipers,
GM mid sized car outer bearings.
If you do this, take the tuip thats posted on the BonusBuilt web site;
clean up your spindles really good, place the bearing adapters in your oven at 400+ degrees. Then one at a time take them out of the oven and slip them over your spindle. then you just need to tap them in place to seat them instead of having to beat the heck out of them. (i made a driver out of pipe)
Bobby
Old Nov 21, 2005 | 04:01 PM
51ford fan's Avatar
51ford fan
Check out this site for the disc brake conversion, I followed this article and bought all my parts calipers, rotors ect from Shucks. I purchased the mounting brackets, and inner bearing adaptors from CPP. http://bonusbuilt.com/dandisks.html
Old Dec 2, 2005 | 06:08 PM
docholiday72tx's Avatar
docholiday72tx
***** B, Your idea has me curious. I don't see why it wouldn't work out side of the drag link issue. I wonder if a person could use the 73 to 79 spindels that are set up for disk breaks and then use a rack and pinion set up?
Doc
Old Dec 2, 2005 | 10:09 PM
cbfomoco's Avatar
cbfomoco
does anyone make a kit to use ford calpers?
Old Dec 2, 2005 | 10:23 PM
51ford fan's Avatar
51ford fan
Don't know of any, the ones I used are for a mid 70s full size single piston GM caliper.
Old Dec 3, 2005 | 08:55 AM
GreatNorthWoods's Avatar
GreatNorthWoods
You might try Speedway Motors. I seem to remember that they sold a kit at one time that used Grenada calipers but I can't remember if it was on the truck kit or for a passenger car...
Vern
