transmission question
Old Aug 4, 2005 | 09:18 PM
cbjr61's Avatar
cbjr61
Question transmission question
i bough my truck a week ago 1991 f150
checked tranny fluid there is to much in it what should i do with it
does this cause tranny problems
thanks
Old Aug 4, 2005 | 09:35 PM
Overkill-F1's Avatar
Overkill-F1
If you have too much atf in there, you can drain it by disconnecting one of the cooling lines and turn to engine over for a second or two at a time (disconnect the coil wire so it doesn't start). I'm sorry to ask this, BUT, you did check the fluid when it was warm, engine running, trannie in park, truck on level ground, didn't you? ...Terry '90 F150, 302, aod
