c6 Trans ,,,,HELP!!
Old Oct 27, 2002 | 09:21 PM
Schwee's Avatar
Schwee
c6 Trans ,,,,HELP!!
Gents......
Put your transmisson hats on guys !
1979 4x4 f150.... frame rebuilt,,, reconditioned most everything over the last 9 months,,, except the trans as it was done 3 years ago and has about 10,000 miles.
i put an external fan driven cooler/filter on it,,, left the stock filter off.... also had to " home - weld " a transfer case frame mount....that summarizes my efforts to date,,, now....all of a sudden two "things" have started to happen...
1. when cold, it is slow to go into gear,,, forward or reverse....
2. form a standing start,,, when i moderatly "punch" the throttle, it more or less "pops" outta gear,,, this does not happen unless iam accelerating from a standing start.....
could it be .... vacum modulator or a band adjustment????
ne thoughts would be greatly appreciated ..
Schwee........
Old Oct 27, 2002 | 10:41 PM
LxMan1's Avatar
LxMan1
c6 Trans ,,,,HELP!!
Try putting the stock filter back in it, it also acts as a pickup for the fluid. May be sloshing the fluid away from the valvebody without the filter on it.
Old Oct 28, 2002 | 01:48 AM
Torque1st's Avatar
Torque1st
Posting Legend
c6 Trans ,,,,HELP!!
Good call Jimmy.
Put a new OEM filter back on. Keep your external filter/cooler also since the OEM filter is not much of a filter at all.
Just a one bubbles of air can mess a tranny up. You can also destroy your pump, clutches, and bands.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Oct 28, 2002 | 08:45 AM
76supercab's Avatar
76supercab
c6 Trans ,,,,HELP!!
