Roller Lifters
Old Aug 3, 2005 | 02:03 PM
debestuss's Avatar
debestuss
Roller Lifters
Somebody tell the advantages of roller lifters. This is what I'm looking at on Ebay, Item number: 7990044299.
Also, check this out, Item number: 4565785605
Old Aug 3, 2005 | 02:15 PM
Freightrain's Avatar
Freightrain
In most applications the roller lifter allows the ramps of the camshaft to be steeper, thus allowing the overall max lift be attained quicker and stay open longer...thus allowing more fuel/air and more power.
Usually the roller lifter itself is no advantage alone. Most camshafts are made specific for a certain lifter and you can not switch them around.
Most times with a roller lifter a much stouter spring is recommended due to the fast ramp speed and the tendency of the roller to fly off the top of cam lobe. So a much higher spring rating is needed, and it's more prone to wearing out the spring(depending on how radical the ramps on the cam are).
They are used pretty much everywhere in stock motors today, but the camshaft is very mild in design because of it.
Old Aug 3, 2005 | 02:26 PM
debestuss's Avatar
debestuss
Oh. Okay. Is that something that you use? I've already bought a 343941 cam so it's probably not compatible, is it?
Old Aug 3, 2005 | 02:32 PM
ford390gashog's Avatar
ford390gashog
the 941 is a flat tappet cam. there is no need for these setups unless you are building a high rpm race motor. make sure not to use a SM rated oil in your engine as it has very low zddp and you will wear out the cam fast or shear a lobe off. use SL/CI-4+ rated diesel oil.
Old Aug 3, 2005 | 02:35 PM
bshackelford711's Avatar
bshackelford711
what is a good weight diesel oil to run in a 390?
-Brandon-
Old Aug 3, 2005 | 02:41 PM
Freightrain
I run solid lifters in all my stuff. I never wanted to step up to the next level. Just too pricey for me.
Old Aug 3, 2005 | 02:42 PM
debestuss's Avatar
debestuss
I know what you mean. Thanks, Larry.
Old Aug 3, 2005 | 02:43 PM
ford390gashog
15w40 is the normal weight and 10w30 is a little harder to fiind. i like delvac or rotella 2 any good dielsel oil will be a huge upgrade from running regular oil. the add pack is very strong and has lots of anti wear additives. delvac is good if you have leaks it has a special base oil which helps in seal swell. delo has over 200ppm of moly and lots of boron which are good barier lubes. rotella has been industry standard for years in the truck industry. the valvoline oils are very weak compared to these so i would not even bother with it.
Old Aug 3, 2005 | 02:49 PM
bshackelford711
15w-40 is that to thick???
Old Aug 3, 2005 | 02:50 PM
hiball3985's Avatar
hiball3985
HEY freightrain, I'm with you, I run nothing but solids, and I actually enjoy adjusting valves, we must be few and far between
Old Aug 3, 2005 | 02:55 PM
ford390gashog
it all depends. how many miles on the engine and clearance. but in most cases no, it is the perfect weight for them. 20w50 yes but not 15w40
Old Aug 3, 2005 | 03:00 PM
bshackelford711
i have just rebuilt my 390. all of my clearances are at about .001 to .0015
Old Aug 3, 2005 | 03:03 PM
ford390gashog
have you run it yet? what is the oil pressure when hot at idle?
Old Aug 3, 2005 | 03:18 PM
bshackelford711
yeah with 10w-30 oil the oil pressure is about 30 psi that is idle at about 650 RPMs (I think i will have to double check that some time to make sure but i think that was preddy close it what i had)
Is that good or bad?
I have not done any other tuning to it just started it and got the cam broke in. Then that has been it for about two weeks now.
Maybe i might do some more to it this weekend
Old Aug 3, 2005 | 03:28 PM
ford390gashog
is that hot idle with 30 psi? thats pretty good. what kind of oil is that.
