Finding Top Dead Center 239 V8 Flathead
I performed this last night:
The small bump on the pulley is lined up with the pin on the gear cover, both #1 exhaust and #2 intake valves are down and have a slight gap at the bottom where the lifters are. I turned the crank slowly clock wise and after a bit the #1 valve begins to travel up and as i keep turning and the bump is making its full orbit the #1 begins to go back down and then the #2 valve begins to travel up and when the bump reaches its full 2nd orbit both valves are down and both have have the same gap once again.
So after 2 full turns they end up where they started.
I hope this is what is supposed to happen
I see you have been away for a couple of years. Well, there are some of the old characters still on the forum and a whole new cast for you to meet.
As far as the timing goes, that's what is supposed to happen. As you turn the engine over, the intake valve will close and you should have a full crank revolution (approximately) before the exhaust valve starts to open. TDC on the firing stroke is at the middle of this crank revolution, with the piston at the top of its travel.
As far as the exact timing chain markings and chain/tooth alignment, one of the flathead gurus will be along to confirm your bump and pin settings.
I can't explain it any better over here so I'll give these guys a shot. Your engine looks good over at bonusbuilt - same color as the merc I put back in my 48.
edit: Never mind, I can't shut up. You described it right - you should be right on. If you had the head off you'd see the piston at the top of the cylinder and both valves shut at TDC.
ON the exhaust stroke you'd see the piston at the top of the cylinder, but the exhaust valve would be open.
There will be a point where both valves will be open a little at the same time. This overlap is intentional and is designed into the cam. Having the exhaust closing slightly after the intake begins to open helps the cylinder draw fresh air/fuel into the chamber by the vacuum created as the exhaust gasses are pushed out. That's the theory at least.
