Tachometer problems
Old Aug 3, 2005 | 09:08 AM
Lil Abner's Avatar
Lil Abner
Cool Tachometer problems
Hi, I have a 87 f250 with a 6.9, the tach sits on 0 when the truck is not running when started it goes backwards to 4200 redline I already replaced the sensor at the injection pump. (help) Thanks in advance.
Old Aug 3, 2005 | 04:10 PM
351M's Avatar
351M
Never seen this one, a short maybe?
Old Aug 3, 2005 | 09:42 PM
PLC7.3's Avatar
PLC7.3
"""I already replaced the sensor at the injection pump""""........... the sensor is on the timing gear cover not the injection pump.
Old Aug 4, 2005 | 07:18 AM
csramsey640's Avatar
csramsey640
yep on the top of the timing gear cover at around the 1-2 o'clock position, with 2 wires coming out
Old Aug 4, 2005 | 09:40 AM
Lil Abner's Avatar
Lil Abner
Sorry yes it is on timing cover, but I replaced the correct sensor Thanks
Old Aug 4, 2005 | 01:17 PM
bbranch's Avatar
bbranch
I have a '91 with a similiar problem, except perhaps even more erratic (sometimes goes backwards like you describe, sometimes just goes really fast forward, way faster then the engine is actually revving). I also replaced the sensor, since that is apparently what usually goes out, and I tried to trace for shorts, but to no avail. Current thinking by my mechanic is that its the actual tach in the dash, but since that is ~>$300 and I usually shift by ear anyways, I haven't replaced it.
Old Aug 4, 2005 | 05:01 PM
351M's Avatar
351M
It is possible that the Tach in the dash is doing this but I should also ask, how are the other guages functioning? A tach from the wreckers should be cheap.
Old Aug 4, 2005 | 09:47 PM
bbranch's Avatar
bbranch
I don't know about Lil Abner's but all the rest of my guages work just fine. I haven't pursued used tachs, but probably will. I think its a pretty rare failure, so a used one should be a good risk.
Old Aug 5, 2005 | 02:15 AM
Lil Abner's Avatar
Lil Abner
yes all my other guages work fine just the tach with problems
Old Aug 5, 2005 | 08:09 AM
PLC7.3's Avatar
PLC7.3
Lil Abner and bbranch I have a tach test for the 93 it may work on yours too.... email me by clicking on my name and sending and I will forward it. Mention Tach test info please....
Old Aug 5, 2005 | 09:54 AM
bbranch's Avatar
bbranch
Doh! I won't be able to send email for about 13 more days (site limits email privlegdes to users who have been registered for 15 days).
Old Aug 5, 2005 | 08:49 PM
Lil Abner's Avatar
Lil Abner
Iam also in the same boat with bbbranch just joined this forum no email privleges.My main concern for the tach is it sounds like my engine is revving to much before shifts ,(c6 auto) shifts at 27mph and 48mph 3:54 axle is this normal thanks
Old Aug 5, 2005 | 09:24 PM
bbranch's Avatar
bbranch
(glad mine's a stick)
If its affecting the shift points, then I would *think* that its more then the tach in the dash. Unless the trans is getting its info from the tach, but I would think it would be taking it from the sensor directly, which you've already replaced... hmmm...
Hopefully some smarter person can help you out
Old Aug 5, 2005 | 09:46 PM
Lil Abner's Avatar
Lil Abner
Hi I dont know if this is a problem or if its normal it shifts fine otherwise I would just like to know at what rpm its shifting
Old Aug 7, 2005 | 12:01 AM
PLC7.3's Avatar
PLC7.3
Lil Abner do a signature re the info about your truck..... go to Quick links at the top and put all the info you can........ we all refer to that info for correct answers to your problems as there are several different systems for different years......thanks.
