AOD problem
Old Aug 3, 2005 | 08:31 AM
Skyjockey's Avatar
Skyjockey
AOD problem
Hi,
New member here. I have a 91 E 350 with the 7.3 and AOD. I recently had a bad exhaust valve guide in the # 2 hole and had to replace the heads. I noticed before I did the work that the tranny was shifting a little differently than it usually did. Now that the engine is back to running like it should, the shift problem seems to be more pronounced. Some times it shifts hard between first and second and then second and third. It normally shifts soft. Almost like it slides from one gear to the next. But in all cases, when it shifts into OD, it wanders. It won't stay in OD unless you apply more throttle. When it backs off, it goes into a gear that seems to be somewhere between OD and third. Any help?
Thanx
Old Aug 4, 2005 | 05:21 AM
PLC7.3's Avatar
PLC7.3
First the AOD is only on E150, I think yours is the E40D check your door post tag for the code letter (E).
Old Aug 4, 2005 | 06:17 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by Skyjockey
Hi,
Thanx
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 4, 2005 | 07:02 AM
Casey's Avatar
Casey
You don't have the FIPL adjusted correctly. That is the sensor on the injector pump that tells the trans computer how far you've pressed the pedal.
And yes, it's an E4OD. The AOD doesn't mate to the 7.3L.
Old Aug 4, 2005 | 07:32 PM
Skyjockey's Avatar
Skyjockey
Thumbs up
Casey,
Thank you very much. This was a 2 part problem. Seems the FIPL was only slightly out of adjustment, but the big culprit was that the last guy that worked on my van in Oklahoma set the idle too high. I could not get the low end voltage to drop below 1.23 vdc. I adjusted the idle and then adjusted the FIPL voltage and it shifts like a new one! Just one question though....does anyone know who the wise guy was that decided to plug the torx holes in the screws with potting material? My 7.3 is in a van, which working on the engine is about like building a ship in a bottle to begin with and then they pull this crap!!
Anyway, thank you very much for your help!
If I can ever help you, (don't know in what capacity that would be) I'd be happy to.
