They Just Dont Fit !
Old Aug 3, 2005 | 05:58 AM
e william's Avatar
e william
I went to put the head gaskets on last night and they just dont fit. It appears the gaskets (metal Fel-Pro) leave an edge of the water ports open to the ports that the push rods go thru...oil and water and air shoud'nt mix....right?!
The new fel-pro is #7636
The old gasket seams to be one that had a blue coating on it with the #7999PT
If anyone knows what type the old gaskets is or of the right gasket that is needed I would appreciate the lead.
motor is an EBV 239-CF Ed
Old Aug 3, 2005 | 06:22 PM
e william's Avatar
e william
Talking Problem Solved
Went to a local parts shop (not adv. or auto Z.) He looked up the two gasket numbers for me and could'nt even find a listing for the new one that wasnt right...go figure.
Found the old one was a fel-pro as well....He went to the back and came out with a stack of about 2 doz. and asks me "how many you want?".
Turns out they had bought out some old shops inventory years ago.....
The new gaskets match perfectly with the old ones.
I hope this is the end of the head gaskets questions....
anybody needing a fel-pro #7999 for a 239 OHV
head # EBV 6090-A on block # EBV-6015 just Private message me and I'll get you a ph. number.
Ed
Old Apr 25, 2006 | 10:43 AM
lbengtson's Avatar
lbengtson
Same head gasket problem
Hi
I have the same problem. Can you tell me where to get these gaskets?
Old Apr 25, 2006 | 11:03 AM
exidenick's Avatar
exidenick
Try at NAPA They are part # 1176TC
Old Apr 26, 2006 | 06:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome lbengtson to Ford Truck Enthusiasts!
…..See you on the boards.
