Sponsored by: Auxito
Clear Corner Question
Old Aug 2, 2005 | 10:57 PM
volstd's Avatar
volstd
This is probably a stupid question because you usually get what you pay for but I am interested in buying some clear corner tail lights for my truck and I noticed on Ebay that there are some for under $20 and at other respectable sights like J C Whitney, you can pay over $100 for them. Will the cheap ones be more likely to get moisture in them and crack or am I worrying too much. $20 sounds a lot better than $100.
Old Aug 2, 2005 | 11:09 PM
Smaug's Avatar
Smaug
I've got some of the cheap tails on my truck and they don't leak.
Old Aug 3, 2005 | 07:40 AM
furrby's Avatar
furrby
if it is just the corner. then 20 dollars is fine. the headlights run about 100 bucks. i got my corner for 20 dollars.
furrby
Old Aug 3, 2005 | 08:18 PM
volstd's Avatar
volstd
Thank to all..........
I'll give the cheap ones a try. They look every bit as good as the expensive ones. I now see that clear corners are not tail lights. I guess I meant the Altezza tail lights.
Old Aug 16, 2005 | 05:10 PM
STX03F150's Avatar
STX03F150
ive got $10 corner lenses on my truck that ive had for over 1 1/2 years and i have not had 1 problem with them.
Old Aug 17, 2005 | 03:08 PM
Fxxer's Avatar
Fxxer
I bought clear corners for my f-150 a week after I got it and they were made by APC and were about $89. 3 years later no moisture and no problems. I always say you get what you pay for, but I think it is more luck then anything. Sometimes you pay a little and get lucky other times you more and get junk, I think it is Newton's Law!!!03' Supercrew 5.4L Fx4
Old Aug 18, 2005 | 06:40 AM
lariat97's Avatar
lariat97
I have some Ebay taillights that are 2 yrs old with no leaks or discoloring. i paid about $45 with shipping.
Old Aug 21, 2005 | 05:08 PM
FordTrucks4Life's Avatar
FordTrucks4Life
If you are worried about the cheaper ones leaking then run a small bead of caulk around the seam where the lens and housing meet. That ought to cure up any chances of them leaking. Also look at the corners and anywhere else you might think water could enter add a small bead of caulk. (Just my two cents, and its what i am gonna try when mine come in and i return from Iraq.)
