Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Lock on tool box jammed
Old Aug 2, 2005 | 10:55 PM
Bargod's Avatar
Bargod
We moved from Lawrence to Wichita Kansas, and when I tried to openmy bottom box tonight, the key will not open the box. I was in quite a hurry when I loaded them up into my truck and had to lay the bottom box on its back to make it under the tonneau. Now only the left side of the box will unlock. Any sugestions on how to get it open? Please keep in mind that I would like to use the box at a later date, so the jaws of life probably won't work. BTW, its a Craftsman box.
Old Aug 3, 2005 | 03:36 AM
psychlopath's Avatar
psychlopath
Drill the lock. If it's the same as my standing tool box, also a Craftsman, the locks are cheap and easy to replace.
Old Aug 3, 2005 | 06:23 AM
EBTDM's Avatar
EBTDM
If it is the lock itself I agree, 'Drill it'.
You may also give it a second look and make sure that it is not the mechanism that goes through to locking the other drawers. These may be jammed from items moving around during the move, considering the way it was laid down. If this is the case consider turning the box upside down and giving it a few shakes, to move the jamming items away from the locking bars and what not.
Old Aug 3, 2005 | 08:53 AM
Bargod's Avatar
Bargod
I tried the whole shaking bit, but no luck. Thanks for the fast replies. I guess I'll look for a drill and go to work.
Old Aug 16, 2005 | 10:35 PM
Bargod's Avatar
Bargod
Turns out that I didn't need to drill after all. The problem wasn't the lock, but the sliders in the back got jammed. I pried the sheetmetal on the back out far enough to get a screwdriver in and used it to lever up the latch. Something must have been jammed in there because now everything works fine.
Old Aug 16, 2005 | 11:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
You just forgot to kick it right...
Old Aug 17, 2005 | 01:07 AM
Bargod's Avatar
Bargod
I might have not kicked it right, but you can believe I kicked it. I talked bad too it, I threatened it, and I was about ready to drill into it when I got the idea to try and reach the latching mechanism.
Old Aug 17, 2005 | 01:16 PM
Torque1st's Avatar
Torque1st
Posting Legend
Did you say bad things to the poor little tool box... Shame on you! -hehe
wasowski
Kansas Chapter
372
Nov 6, 2020 08:43 AM
azroxx
Jun 25, 2015 04:10 PM
Fameus
Kansas Chapter
Mar 3, 2015 07:26 PM
old broke prospector
1947 and Older Ford Trucks
Jul 25, 2013 02:59 PM
ruskeigunlover
2009 - 2014 F150
Jul 3, 2013 06:05 AM
