transfer case?
Old Aug 2, 2005 | 09:27 PM
mchiz's Avatar
mchiz
transfer case?
Lately when our '99 is put into reverse, we hear a "clunk". My husband thinks this is the transfer case.
Anyone want to shed info?
thanks,
Marie
Old Aug 2, 2005 | 09:44 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Marie, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 3, 2005 | 02:59 AM
Monsta's Avatar
Monsta
Sit. Stay.
How 'bout we start with this...
Is is a 2x4 or 4x4? (I'm Assuming 4x4) Can't remember but does your 99 have a 2HI option or is it A4WD?
How many miles are on it?
Does it happen everytime?
It may be as simple as driveline slop or a slip joint that needs lubed or even a bad U-joint.
Old Aug 3, 2005 | 08:41 AM
PaulC's Avatar
PaulC
1999 - 2002 Expys have A4WD, 4HI and 4LO as transfer case switch selections.
Old Aug 3, 2005 | 09:34 AM
Trucker22's Avatar
Trucker22
Clunk
My experience with other vehicles is that a clunk when shifting forward/reverse direction has always been caused by worn out drive shaft Universal joints---with that mileage that might be a good bet---easy to check. As they get worse you may start to notice slight squeaking while rolling slowly in reverse.
It's just a thought--easy to check and not too expensive to repair---if you do replace U joint---I'd do both at the same time and the new ones may have grease fittings that the OEM doesn't have
Old Aug 3, 2005 | 04:02 PM
mchiz's Avatar
mchiz
Thanks for you all getting back to me so quick, I am sorry I didn't read the guidelines before posting, we have a AW4WD, 72,000 miles and it happens most of the time. After reading the replies to my husband he says it could be the u joint. We've made an appointment with our mechanic to check out.
Marie
