I need to replace my passenger towing mirror and cannot see how to remove the inside door panel so I can get to the electrical harness. I can remove the nuts fine and get the mirror loose, but see no way to get the door panel off? I need to get to the conector from the mirror to the main wiring harness.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
It is a simple procedure. There are two screws that hold the door panel on. The first is behind the inside door reflector at the bottom of the door panel, and the second is behind your door lock/ power window switch. the panel just pops off and you will see the screw. Then you just lift up and out on the panel and it will come off. You will need to unscrew the light at the bottom of the panel
