wheel cyclinders
Old Aug 2, 2005 | 03:38 PM
Ford150/428/dud's Avatar
Ford150/428/dud
wheel cyclinders
i have a problem i just finished painting the back side of the fram along with the springs and the rearend. I got it all put together and i found out that both of my wheel cyclinders are junk so i went to take them off and to find out that the person that owned the truck before me stripped the heads off the bolts holding the wheel cyclinders on. What should i doo?
Old Aug 2, 2005 | 06:50 PM
Ecuri's Avatar
Ecuri
Use a grinder or dremel with cut off wheel to remove the bolt heads, the wheel cylinder will then fall out.
Old Aug 2, 2005 | 07:59 PM
Phinxter's Avatar
Phinxter
vise grips, or a bolt out from sears works too.
