I have 31x10.5 on a stock 95 4x4 ORD, stock alum. rims, no problems, and look good. Trying to find a good pressure, 35 too soft, 40 a bit hard, but much better control.
Reason: clarity
NP pineappleking, My 1991 F-150 lariat has 32 x 11.5 on it but they rub when turning.........monday i get my 6 inch pro comp lift and 35x12.5....Can't Wait!!
The 32/11.5s will rub if they're on the stock rims. Aftermarket rims may have enough backspacing to prevent it. I have skyjacker radius arms that are bent in to give more tire clearance and those 32s still rub. My 35s rub pretty bad after I put the 393/zf in. I lost about an inch in my front lift because those parts are heavier then the 302/m5 i had before. I rub the fender and the radius arm semi-bad now. It's unacceptable to me now but i can't fix it as of yet. I have other things to deal with.
