Cap? Whadya think.
Old Aug 2, 2005 | 08:50 AM
i1dery's Avatar
i1dery
Question Cap? Whadya think.
New water pump,new thermostst,new antifreeze.
After my truck gets good n hot needle at the r in
normal, its time to retire for the evening, by morning
get out to the truck(460cid) the upper radiator hose
is collapsed flatter than a pancake. Im suspecting its
the radiator cap seeling so tight that its not allowing
fluid to be sucked out of my overflow resevior into
the radiator. Whadya Think?
Old Aug 2, 2005 | 09:43 PM
Pikachu's Avatar
Pikachu
That would be my guess. On most pressure caps, the smaller metal inner ring under the cap is supposed to open under suction to allow coolant recovery. Try a new cap for $10, and it should be fine.
Old Aug 3, 2005 | 07:15 AM
i1dery's Avatar
i1dery
Went to napa last night for a new cap. I'll see tha results later
when i home and can keep an eye on it overnight. And if that dont
work than it just must be normal.
