big block help
Old Sep 28, 2002 | 06:04 AM
theonlybull's Avatar
theonlybull
big block help
Old Oct 31, 2002 | 03:27 PM
okiebronco's Avatar
okiebronco
big block help
hey guys im new here just thought id say hello and ask a question. when it comes to the what are the visual differences between stock 390s and bigger blocks? i just bought a 78 f-150 from an elderly lady that didnt knwo anything about the truck and i cant read the casting numbers on the block. im almost certain its nto a 351m-400 im rpetty sure its a 390 or 460 but looking for some help figuring it out. but then again i hear there was a 360? big block also?
Old Oct 31, 2002 | 04:04 PM
76supercab's Avatar
76supercab
big block help
Look at the intake manifold. If it extends under the valve cover then it is an FE. Now it could be a 390, 360, 406, 428, 427(probably not) no real way to be sure without tearing it down. Others can offer tips on recognizing a 460 or a 351M/400.
Old Oct 31, 2002 | 04:11 PM
okiebronco's Avatar
okiebronco
big block help
[updated:LAST EDITED ON 31-Oct-02 AT 05:12 PM (EST)]forgive my ignorance here. what does FE stand for. also with stock valve covers what are the differences? i know some are flat topped and some are rounded
Old Oct 31, 2002 | 04:39 PM
73Custom's Avatar
73Custom
big block help
That's been a big debate in the past, but most documentation refers to it as Ford Edsel. Henry's son that started a new engine line in the late 50's for the cars and went into the trucks in the late 60's through '76.
For the differences in the engine families, drop down to the engine forums and search the past posts. They talk often about identifying features.
Marty
Old Nov 2, 2002 | 01:32 PM
fordguy76's Avatar
fordguy76
big block help
key
351/400M 8 valve cover bolts
429/460 7 valve cover bolts
302/351W 6 valve cover bolts
360/390FE 5 valve cover bolts
Old Nov 2, 2002 | 01:41 PM
Bill_Beyer's Avatar
Bill_Beyer
big block help
If it's stock it didn't come with an FE. They stopped putting the FE engines in F series in 1976. If it's a 4X4 then it's not a 460 because they didn't start putting 460's in F series 4X4s until 1983. Since it's an F-150 I'd be highly doubtful that it's a 460 which I believe were only available stock in 2WD F-250s and above in 1978. There's a very good chance it's a 351M or 400.
Of course if it's not the stock engine than all bets are off.
Old Nov 3, 2002 | 10:30 AM
Ford79's Avatar
Ford79
big block help
460's were available in 2wd F-150's starting in 74 or 75. I have a 78 F-150 that came with a 460.
