Upper radiator hose ?
Old Aug 1, 2005 | 11:22 PM
88F-150pimp's Avatar
88F-150pimp
My '88 radiator hose bends in front of the power steering pulley, and now has a large gouge in it because of the pulley. Ford changed the design in '92 i think. I got a '96 hose today at auto lone, but it doesn't look right at all. Pretty sure its the wrong one, even for a '96. I looked at the hose they had on advance auto's site, and it is the right shape, but says its 3.5" shorter, as far as waterneck to radiator. Is it really?? Every picture i've seen of a 92-96 F-150 has the same radiator and water neck spacing as my '88. Anyone know for sure? I would really like to get a hose that won't be eaten by the power steering pulley.
Old Aug 2, 2005 | 01:33 PM
1975Ford's Avatar
1975Ford
Buy the hose for the 92 -96. Try a general test fit. If it look like its going to fit, try it. If it dosen't, take a back for a refund. It's a fast and quick way of checking if it's going to fit. Try not to get the hose dirty or you will have a difficult time with a refund. Good Luck.
Old Aug 12, 2005 | 07:58 PM
89whitenight's Avatar
89whitenight
You've probably already fixed the problem by now, but I had to deal with this problem a little while ago. The hose the auto parts store stocks will not fit right off the shelf, they are made with a little extra on each end, you have to trim them to fit your truck.
