my first one stopped driving!!!
Old Oct 31, 2002 | 03:51 PM
gotmyfirst1's Avatar
gotmyfirst1
my truck (1977 ford f-250) starts okay but won't accelerate past 15 mph and dies just minutes after driving it! i've run it for 10 minutes before driving but still get the same results. any help would be appreciated!
Old Oct 31, 2002 | 04:31 PM
73Custom's Avatar
73Custom
What engine, carb, transmission do you have? Have you done anything to it recently? Did it start all of a sudden, or has it always done this? Does it idle good? Does it run smooth when reved up?
There are several things that would cause the trouble you are having...check them out.
timing
air filter
choke operating properly
fuel filter
fuel pump
vacuum leak
bad dist cap, rotor, wires or plugs
Marty
Old Nov 1, 2002 | 12:48 PM
jalampi's Avatar
jalampi
Need more info on the truck.
Might be a bad fuel pump.(just guessing).
Old Nov 2, 2002 | 08:59 AM
jimlj's Avatar
jimlj
Change your fuel filter before you dump a ton of money in other repairs. A motor will start and idle fine on low fuel flow, but starves for fuel at higher rpm.
Old Nov 2, 2002 | 10:32 AM
Mike W's Avatar
Mike W
It sounds like the classic symptom of a bad fuel pump. It will idle but only drive a short distance.
Old Nov 2, 2002 | 02:50 PM
gotmyfirst1
engine-351
carb & transmission-??? (how do i check this?)
had the carb and choke adjusted
the morning that it died was the first time it did it
Does it idle good?
idles great after it warms up
before it broke it revved great
timing
air filter-brand new
choke operating properly-just had serviced
fuel filter-new
fuel pump-good pressure
vacuum leak
bad dist cap, rotor, wires or plugs-all 8 cyl have spark
Old Nov 3, 2002 | 08:43 PM
78f150m's Avatar
78f150m
i dont know if its a bad fuel pump it might be the accelrator valve
Old Nov 3, 2002 | 09:48 PM
taz3fan's Avatar
taz3fan
ok is it a diesel......if not try a ford module or dura spark.they work in alot of different ways when bad......had a 77 bronco wouldnt get over 30 mph without stalling changed module and quik fix
Old Nov 3, 2002 | 11:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
