Sponsored by: Auxito
k@n air filter
Old Aug 1, 2005 | 07:09 PM
f150getsitdone's Avatar
f150getsitdone
k@n air filter
i have a 99 f150 are the k@n air filters good to buy
Old Aug 1, 2005 | 07:18 PM
triton_2002's Avatar
triton_2002
Welcome to FTE!
Do a search here for K&N and you'll get all kinds of opinions, then you can decide for yourself.
Old Aug 1, 2005 | 07:20 PM
jlillie's Avatar
jlillie
ping pong ball test
I once saw an air-flow ping pong balll test where they blew air throgh a K&N or stock filter (depending on which was installed). When the K&N was in, the ping pong ball was blown all the way to the end of a tube and hit the stop. When the stock filter was in the ball didn't even make it 1/2 way up the tube. I was rather impressed by this. This was at a parts store and they said I could pull the filters off the shelf myself if I thought the filters they were using were mocked up so I took them up on the offer and did. - Seeing is believing.
Also, since putting K&N in both my wifes Sable and my F150 I've never bought another filter. I just clean, re-oil and re-install. How can you beat that?
~john
Old Aug 1, 2005 | 07:28 PM
lariat97's Avatar
lariat97
I run K&N filters in all my rides. I have one in my quad too. It has the sock on it for small particles. I've never worn one out. Its a good mod IMO
Old Aug 4, 2005 | 09:19 AM
TOOT's Avatar
TOOT
Just use restraignt when reoiling the filters after washing. People complain that they (K&N filters) ruin MAC's, but if you don't over oil you shouldn't have a problem.
Old Aug 4, 2005 | 09:41 AM
MrBSS's Avatar
MrBSS
I previously used K&N's in all my vehicles, but I don't recommend them now, especially for Fords with the truncated cone type filters. Those are very aerodynamic filters and are unlikely to present much restriction.
I do think the K&N's pass somewhat more dirt. This probably is not noticeable in normal usage, but will show up as increased throttle body contamination and valve wear above 100,000 miles.
I wouldn't claim this is a real scientific test, but I do have two vehicles, purchased new, that now have in excess of 250,000 miles each. One got a K&N and the other didn't because that size was not available. While both still run quite well, the K&N equipped vehicle has often required throttle body cleaning and uses a quart of oil per 1000 miles. The other has had its throttle body cleaned, but has never had stalling problems due to that. It uses no oil.
Old Aug 4, 2005 | 03:47 PM
cjl's Avatar
cjl
if your willing to pay the money i would recommend that you get the whole k&n cold air intake. i noticed a difference in power. it also helped a lot with running nitrous.
Old Aug 4, 2005 | 05:30 PM
Octane's Avatar
Octane
I think the claim that a K&N doesnt filter as well as the OEM paper filter is BS. The K&N meets the same filtering standards as the OEM filter.
I have a K&N filter in my '99 F-150. The throttle response seems a little bit quicker and Ive gained 2 mpg.
We've used K&N filters on all of our vehicles for years. We are yet to have a single problem with any of them.
Octane
Old Aug 4, 2005 | 06:06 PM
cjl's Avatar
cjl
the only way i could see k&n lot filtering as well as stock is if you never added the oil to help grab dust and other particles. i do a ton of off road driving and drive through dusty cornfields at work and i've never had a problem with it not filtering well.
Old Aug 4, 2005 | 06:13 PM
tb40nd's Avatar
tb40nd
you noticed a difference b/w running "just" a K&N filter and running the whole cold intake kit? or are you comparing the K&N cold intake kit to the stock filter?
i ask b/c i have been wondering how much of a difference there is b/w running a K&N with the stock intake vs. running the complete kit. i bought the filter and modified my stock intake kit to allow more airflow, but now i'm wondering whether i should have gotten the whole kit?
Old Aug 4, 2005 | 08:05 PM
cjl's Avatar
cjl
i noticed a difference from just running the filter compared to running the whole kit. you won't notice it as much if the rest of the truck is stock. but i have headers and am running 100 shot nitrous and it made a huge difference. it really let my engine breath a lot better.
Old Aug 4, 2005 | 08:12 PM
Octane's Avatar
Octane
The cold air intake lets the engine get a lot more air than it would with the stock airbox.
However, unless you have headers, a high-flow cat and duals, I dont think it gains you much other than noise. Its like trying to pour a 50 gallon barrel through a straw vs. trying to pour out a 20 ounce bottle through a straw, either way the water will only pour out so fast because of the bottleneck at the straw.
Octane
Old Aug 4, 2005 | 08:17 PM
fordborn's Avatar
fordborn
I have always run them on my trucks and never had a problem. Like someone above said if you do not over oil them they will give you no problems. Now when I put just the filter in I notice very little or no advantage over the stock set up so I recommend the whole cold air intake system. With it I definitely noticed a difference in throttle response and in mpg.
Old Aug 4, 2005 | 08:19 PM
cjl's Avatar
cjl
Octane
This is very true but you also have to remember the air that is entering is cooler than a stock intake. which means you will have a more effecient fuel burn which lets you get more power and better mileage. if your planning on doing any later work to the engine you might as well get the kit, if not it may not be worth the money.
Old Aug 4, 2005 | 09:08 PM
tb40nd's Avatar
tb40nd
ahhh... well, other than the filter i'm totally stock at this point but thanx for the tip. i am considering getting a new throttle body, electic fans, and a new ignition system in the near future.
Octane
thanx for the heads up Octane... i think i'll wait till i get the new throttle body before i consider spending money on this then.
i know one thing - with just the filter i sure noticed a difference in performance. man i wish i could afford to do everything at once b/c i just can't wait to see what this thing runs like with the new intake/filter, tb, electric fans, new ignition system, and the single program superchip! i'll have the new exhaust this weekend.
