Sitting a long time.
Old Nov 5, 2002 | 11:10 AM
joetee10's Avatar
joetee10
Old Nov 6, 2002 | 10:42 AM
Dirty_Pile's Avatar
Dirty_Pile
Post Sitting a long time.
I have received a 1974 F250 as a "get it out of my yard" present. The only problem is it has been sitting for 10 years +/-. I am looking for sugjestions on things to go through before I fire it up.
Thanks
Old Nov 6, 2002 | 11:09 AM
jalampi's Avatar
jalampi
[updated:LAST EDITED ON 06-Nov-02 AT 12:10 PM (EST)]https://www.ford-trucks.com/dcforum/DCForumID91/12885.html
Old Nov 6, 2002 | 11:19 AM
73Custom's Avatar
73Custom
If it ran/drove when parked I would:
-change oil
-prime oil pump
-put couple squirts of oil into spark plug holes and rotate engine by hand
-tuneup - plugs, wires, cap, rotor, points (if not elec)
-drain old gas and change fuel filter
That would at least make it safe to start. Then to be driveable I would do more:
-change fluids - trans fluid, rear end oil and transfer case/ front end oil if 4x4
-change/flush antifreeze and change thermostat
-pack front wheel bearings
-check brake system
-check suspension for wear and siezed joints
By then you can safely take it for a short test drive without damaging anything. It's quite possible it will need more, time is hard on things. Carb may need rebuilt, fuel pump replaced, rubber hoses replaced. Brakes and joints may be siezed up from sitting. Fun, fun, fun... Enjoy your new truck...
Marty
