After my 6l gets warmed up on a hot day. If it sits for a while on restart it misfires until driven for awhile and good air flow on engine cools it down. Also happens when towing a load slowly up a hill. Is it electrical?
my 04 super duty is doing the same thing when on the highway in traffic ... misfires and I loose all my boost. does this for about 10-15 second and is fine for a little and starts again. when traffic opens up i blow a big puff off smoke and it runs like a bat out of hell!! i dunno if you found out anything ... just curious.
2003-05 Various Running Problems, Check Engine Light; New EBP Sensor:
Trucks built before 1-17-05 that exhibit buck/jerk, hesitation, lack of power, stalling, stumble, black smoke, surging, rolling idle, changes in engine sound at idle or when driving at a steady speed, or with the trouble codes P2263 or P0299, may have an exhaust backpressure sensor signal that is incorrect or erratic. A revised EBP sensor is available if this is found to be the case. Part number 4C3Z-9J460-A. Broadcast Message 3815.
Normal EBP signal reading should reflect atmospheric pressure with the key on/ engine off. Typically, this is 14.7 PSI/0.88-0.9 volts at sea level, decreasing one PSI/0.10 volt for every 2000 feet of elevation. It should be within 0.5 PSI of BARO and MAP sensor pressure signals.
