Bronco II Ford Bronco II
after market a/c
Old Jul 31, 2005 | 01:57 PM
Canadianice's Avatar
Canadianice
after market a/c
I own an 84 bII and I just recharged the after market a/c which is a r134a system and all the pressure is within spec, but im still blowing hot air. The truck is a 3 speed auto and I can feel the compressor working because my truck looses power when the a/c button is pressed. Im out of ideas all my manuals are for the original system not an r134 system. They look the same in the pics but im lost at what would make it run hoy with the system all charged.
Old Aug 1, 2005 | 08:54 AM
Monty06's Avatar
Monty06
did you change the valve cores and flush the system for adding 134a .
also did you check for leaks
Old Aug 1, 2005 | 05:42 PM
Canadianice
I dint check for leaks, but im sure its not leaking because when I recharged it the pressure was at about 40psi so I drained it and recharged it. how do i changed the valve cores?
Old Aug 1, 2005 | 08:55 PM
Monty06's Avatar
Monty06
do you have gas in there now
if not then you remove cores with a valve core removal tool same for the tire valves.
any auto store should have it. valve core tool
Old Aug 2, 2005 | 10:39 AM
Canadianice
yeah it still at 40-45 psi at the moment. There is one thing I notice is that when the a/c button is on it makes a hissing noise youcan hear in the cab. I dont know what it is.
