Air conditioning help!
Old Jul 31, 2005 | 11:34 AM
ilgette's Avatar
ilgette
Cool Air conditioning help!
I recently attempted to repair the a/c in my 1983 F-100, but it still won't blow cold unless I'M driving over 20 mph, or its dark and cool outside! I have replaced the compressor, drier, evaporater, condenser, blower and 2 lines. What am I doing wrong? I put freeze 12 refrigerent in but it won't get cold. Any suggestions would be appreciated. By the way I have 2 electric fans on it, one pulling through the radiator, and one pushing through the condenser. The condenser fan is tied into the pressure switch for the compressor, via relay, and runs only when th a/c is running. Thank you in advance!
Old Jul 31, 2005 | 11:54 AM
Lee Lichterman's Avatar
Lee Lichterman
The oriface is a key to these. When I converted my rig from R-12 to the new R-134 it didn't blow near as cold as it used to. The old design compressors just don't do as well with the new coolant. I have heard from numerous sources that the oriface is the key and I am going to swap mine out when In get done with all the other stuff I am doing to it right now.
Also, when you charged it, did you make sure you COMPLETELY purged it? A simple drain doesn't do as well as a true vacuum purge. I bought a cheap vacuum attachment for my compressor from Harbor Freight for under $10 bucks and I noticed that it blew colder after I completely sucked the system out to negative pressure then refilled it than when I simply drained it and filled it.
Just a couple ideas I can think of off the top of my head as it appears you have done everything else.
Good Luck,
Lee
Old Jul 31, 2005 | 05:52 PM
fordborn's Avatar
fordborn
Moved to " Cooling, Heating, Ventilation and A/C" Forum. Should be able to have more responces to your question here.
Old Jul 31, 2005 | 09:07 PM
Pikachu's Avatar
Pikachu
Well, let's start with this: what are your high and low side pressures at idle with the air on max and fan on high?
Old Jul 31, 2005 | 09:10 PM
ilgette's Avatar
ilgette
Cool its me again....
When I'm driving down the road with the a/c (the one that isn't very cold) I notice water drops flying out the vent by the passenger side, and water dripping on to the floor. What do you think this could be? I love my truck, but im about to shoot the old girl since she seems hell bent on not having a/c!
Old Jul 31, 2005 | 09:13 PM
ilgette's Avatar
ilgette
Angry
I don't rember off hand, on the old compressor, the high side would fluctuate rapidly, so I returned it and got another one, now its pretty steady. What should the read?(ball park figure?).
Old Aug 1, 2005 | 12:00 AM
motorcyclist's Avatar
motorcyclist
the first thing to start with is make sure you are free of leaks, then get a vacuum pump and leave it on about 10 min. so you are free of moisture and non condensables, then recharge it with the specified weight of refrigerent(you may want to start with about 10 percent less if using an alternative refrigerent), then check both your low and high side pressures.
I work in the commercial refrigeration trade, and have found that alternative refrigerents to those that are phased out do not work that great with a fixed orafice, or capillary tube for a metering device. You may be better off to change to 134a and install the restrictor orafice for the new flavor.
Bill
Old Aug 1, 2005 | 04:17 PM
Pikachu's Avatar
Pikachu
After re-reading your original post, have you checked your fan clutch and/or electric fan? It sounds as though you aren't getting any airflow over the condensor unless you are moving. Your pressures (depending on ambient temps.) should have the high side at less than 275 or so, and on the low side, a pressure of 30.2 will give you an evaporator temperature of about 35f with Freeze12. These pressures aren't set in stone, and may need some tweaking to make the system rum at it's best.
Old Aug 1, 2005 | 07:23 PM
ilgette's Avatar
ilgette
Red face fans...
I checked both fans, they are working as they should, with both on,they will hold a shop towel or rag against the grille when switched on. The only hoses I did not change were the ones going from the condenser to the drier, and the drier to the compresser. I out in a new orifice tube, and ran a vacuum pump on it for an hour before charging it up. Could those hoses be the source of my problems? The pressure readings sound about what it said when hooked up to the gauges. One other question where is the dripping water, and condensation coming out of the vents coming from? a clogged drip hole or something of that variety?
Old Aug 1, 2005 | 11:19 PM
Pikachu's Avatar
Pikachu
Have you opened up the air handler and cleaned out the evaporator coil? If it is packed with crap, that will seriously decrease efficiency.
Old Aug 2, 2005 | 02:08 AM
ford390gashog's Avatar
ford390gashog
did you pull a vacuum?
Old Aug 2, 2005 | 09:54 AM
Holmesuser01's Avatar
Holmesuser01
Pikachu probably has it nailed. Clean out the evaporator!
Makes me wonder how all of this junk gets into the blower box anyway! Mine has wire mesh under the air intakes, yet, there it is.
