identifying mid 50's f100
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and member notified
I will 2nd TIms' Howdy to ya, and welcome to FTE
.I'll also say you would more likely get a better response and more knowledgeable explanation if you are in a forum that deals with those trucks. Here we deal with SLICKS the great 1961-66, F Series, FoMoCo trucks everybody here is into.
If you go back to FTEs' FORUMS PAGE, [click on 2nd tab from left at top of this page].
When FORUMS PAGE opens, scroll on down until you find a forum, I think like 1948 to 60 Ford Trucks since your truck is in that category.
Those guys will get you headed in the right direction much better than we will I'm sure. For one thing they know the right questions to ask you to help them identify it correctly for you. They were good ol' trucks and I know folks who have them today.
Good Luck and I hope you have fun, and enjoy doing your project. Share it with a kid if you can too.
FBp
The VINs were stamped on a rating plate that was mounted to the rear face of the driver's door or the inside of the glove box door. VINs were not stamped on the engine, but they did get stamped on a frame rail.
https://www.ford-trucks.com/user_gal.../80206.520.390
Most of us don't bite, and we try to keep those that do on a leash.
We'd all love to see some pictures of your truck if you can set up your gallery. A number of us are working on trucks that have special meaning - they belonged to a family member, a family member owned one when we were younger, or something similar.
As Randy and Steve have mentioned, the grill is the best way to ID the trucks from the outside. I'd strongly recommend that you spend some time looking for the rating plate - either inside the glove box or on the door pillars. As Steve mentioned, it will also be stamped on top of one of the frame rails (the frame members running the length of the truck) ahead of the cab. You might have to use a wire brush and some detergent to clean off the gunk so you can see the numbers. The VIN will let us tell you what year, engine, and other features the truck had when new.
BTW Randy, you young guys have to remember us old farts who are half blind.
That picture has a whole lot of good information - but I can't read it - even with my short-range spectacles on.
https://www.ford-trucks.com/user_gal...=84681&width=2
http://f100fever.topcities.com/specs5355.html
....ok, ok, maybe I did already know some of those words....
I noticed you started a new thread with a similar post and title as this one. I suspect you may be a little confused (or I might be
). Let me see if I can get you on the right track.First off, to avoid confusion, I removed the new thread and moved your post from that new thread to this one. Here is that post:
Don't worry, we'll help you get to the point where you're cruisin' the threads and forums just fine.Now, back to your original question. To ID the truck for you, we need one of three things. First choice would be the rating plate information. If your rating plate is still in the glove box, it should look something like this.
It is possible that the rating plate has been riveted or screwed to one of the door posts - usually the driver-side between the hinges. If you find the rating plate, carefully write down all the information and post it here. We'll be able to tell you a lot about the original equipment on your truck.
If you can't find the rating plate (glove box is missing or rating plate has been removed), the next best thing is the Vehicle Identification Number or VIN. On these trucks, the VIN is stamped on top of one of the frame rails ahead of the cab. It's usually just behind the front axle, but the folks sitting on the assembly line banging on the letter and number punches with hammers weren't too consistent. You may need to take a wire brush and some solvent or soap and water to the frame rails to clean them up. After brushing them clean, it also helps if you shine a flashlight or shop light across the surface at an angle. Getting the light just right can make the numbers a lot easier to read. If you find the VIN stamped on the frame rail, carefully read the numbers and letters and post the information here.
Finally, if you can't find the VIN (somebody has done an IFS clip and the frame is missing or you've searched everywhere and the VIN has been ground off the frame), take a photo of the front of the truck including the grill. One of the few things that changed between the 1953 through 1956 model years was the grill. If you are uncomfortable trying to post a picture, you can read through the thread at the top of the forum on posting pictures, or, you can send me an e-mail and I'll help you get the picture posted.
Good luck - start looking for that rating plate or go at the frame with that wire brush. We're all waiting to help you figure out what you have to start your project.
