Huge leak, What do I do?
Old Jul 31, 2005 | 06:56 AM
rj1's Avatar
rj1
Cool Huge leak, What do I do?
I have a 94 explorer with 109000 miles. It's in good condition except for now. It's leaking huge amounts of antifreeze from the engine. I show it to a friend and he says there is a leak from the engine not the radiator hoses. What do I do? He says it's a moajor job to fix. What am I looking at in cost? I don't want to lose her. Thanks
Old Jul 31, 2005 | 07:05 AM
marragtop's Avatar
marragtop
Where did your friend say it was leaking from? Head gasket, water pump or what? More info is needed.
Old Jul 31, 2005 | 07:48 AM
rj1's Avatar
rj1
head gasket
He thinks it's from the head gasket. Do these liquid seals work? Thanks
Old Jul 31, 2005 | 01:35 PM
Jharger's Avatar
Jharger
Change the head gasket. Don't fool around with gimic seal products. look at this web site for many explorer fixes.
http://draco.acs.uci.edu/explorer/
Old Jul 31, 2005 | 06:44 PM
mrshorty's Avatar
mrshorty
There are also freeze plugs in the block that are known to fail like that.
I agree, don't fool around with the liquid seals. Even if they worked, they were never designed to seal a large leak like that. Half the time, even if they seal the leak, they plug up something else in the cooling system.
Old Aug 3, 2005 | 02:22 PM
460429_freak's Avatar
460429_freak
also the intake leaks and makes it look like a head gasket /or thermostate leaking...
