ENGINE IDLES FINE,DIES WHEN PUT IN DRIVE
Old 06-26-2010, 09:18 PM
ranger714's Avatar
ranger714
ranger714 is offline
1995 V6 3.O AUTOMATIC, MY SONS GIRLFRIEND WAS DRIVING,SHE SAID IT WAS RUNNING FINE UNTIL SHE PULLED INTO A QUICK TRIP GAS STATION.WHEN SHE CAME OUT SHE CRANKED UP AND WHEN SHE PUT INTO DRIVE OR REVERSE THE ENGINE CUT OFF.
Old 06-27-2010, 08:25 AM
pawpaw's Avatar
pawpaw
pawpaw is online now
Acting out IAC maybe.
Or maybe the torque converter clutch is locked up.
What happens if she pushes the OD switch on the end of the shift lever, so the "OD Off" dash indicator is lit & then tries putting it in gear????
What happens if she puts it in 2nd & tries to move off????
Old 06-27-2010, 09:49 AM
ranger714's Avatar
ranger714
THE AEROSTAR IS BEING TOWED TO MY HOUSE,IT SHOULD BE HERE BY NOON.IT WILL BE EASIER FOR ME TO CHECK.I WILL TURN OFF THE OD AND CHECK THE 2ND AS SOON AS IT ARRIVES.THANKS AND I WILL POST AS SOON AS I CAN.
Old 06-27-2010, 10:26 AM
00Harleydavidson's Avatar
00Harleydavidson
00Harleydavidson is offline
After you get to try it out you will be more able to diagnose the problem. Could be a fuel problem also. Enough fuel to idle but not enough to pull a load. I'll be interested to see if you can rev the rpm's up when in park or if the vehicle stumbles. Also lets hope it isn't a computer problem. Let us know more when you look at it.
Old 06-27-2010, 11:00 AM
ranger714's Avatar
ranger714
Cranked up the van,it revs up fine in park.Also on the column its park/reverse/nuetral/od/drive/2nd/1st.It will stall in any position except park or nuetral.
Old 06-27-2010, 11:04 AM
ranger714's Avatar
ranger714
Could the modulator be the problem?
Old 06-27-2010, 11:13 AM
pawpaw's Avatar
pawpaw
Is the CEL lit???? if so pull & post All of the trouble code Numbers.
Maybe try disconnecting the IAC, the engine may idle rough or stall, but you can keep it going with a little accelerator pedal, then see if it'll move wihout stalling.
If not, switch the OD Off & shift into all gears.
If no joy, I'd suspect the torque converter clutch is locked up, thats sorta like leaving a straight drive in gear when coming to a stop.
How is the tranny fluid condition????
Old 06-27-2010, 11:35 AM
ranger714's Avatar
ranger714
NO LIGHTS ARE ON THE DASH,DISCONNECTED THE MASS AIR FLOW SENSOR,WHEN YOU PUT IT INTO GEAR IT MAKES A LOUD CLANKING NOISE AN QUITS.ASHLEY JUST TOLD ME WHEN SHE PULLED INTO THE STORE THE VAN STARTED VIBRATING PRETTY BAD AND ALL THE GAUGES WERE JUMPING AROUND.
Old 06-27-2010, 11:36 AM
ranger714's Avatar
ranger714
ALSO THE FLUID LOOKS OK AND THE FLUID LEVEL IS FINE
Old 06-27-2010, 11:42 AM
pawpaw's Avatar
pawpaw
Kinda sounds like the torque converter clutch is locked up for some reason.
The dash warning lights coming on & the gauges jumping around on her, was likely caused by the engine about to stall
You need a tranny man to chime in & enlighten us some more.
Old 06-27-2010, 11:50 AM
ranger714's Avatar
ranger714
PAW PAW , YOU THINK I NEED TO REPLACE THE TORQUE CONVERTER?
Old 06-27-2010, 12:07 PM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
Did she get gas at her last stop and thereafter it started acting up? Maybe water in the gas. Try a bottle of dry gas in tank. Also try cleaning MAF sensor and/or look for a leaking vac line.
Old 06-27-2010, 12:14 PM
ranger714's Avatar
ranger714
I JACKED UP THE REAR END,CRANKED UP AND SHIFTED FROM NEUTRAL TO DRIVE AND THE WHEELS TURN WITHOUT THE ENGINE STALLING
pawpaw's Avatar
pawpaw
Well we don't have enough vehicle history to jump to that conclusion just yet & I'm not a tranny guy, I know just enough about em to be dangerous!!!! lol
You likely need input from a Ford tranny tech.
Is the OD light on, or flashing????
Did you ever try turning the OD OFF, by pushing the switch on the end of the shift lever, until the OD Off light in the dash comes on, then trying to shift into gear????
This is supposed to deactivate the torque converter lock up solenoid/clutch, so maybe exercising the OD switch would wake something up?????
Has this vehicle had any tranny problems or repairs before this event????
Old 06-27-2010, 12:19 PM
ranger714's Avatar
ranger714
THERES NO WAY TO DEACTIVATE THE OD, THE VAN HAS BOTH AN OD AND DRIVE POSITION ON THE COLUMN
Quick Reply: ENGINE IDLES FINE,DIES WHEN PUT IN DRIVE
