Summit Catco kit
Old Jul 30, 2005 | 08:54 PM
KShep's Avatar
KShep
Summit Catco kit
Guys, new here so if this is in the wrong place please forgive....
I have a 1990 f150 4x4 with a 5.0. I bought a Catco converter kit (Y pipe and converter) and cat back exhaust from summit this past week. The Y pipe did not have a pipe to connect to the air pump. I dont fully understand the emmissions systems and was wondering if I can use this y pipe setup. I live in NJ and will need to get this truck through inspection.
Thanks in advance for your help.
Old Jul 31, 2005 | 11:36 AM
MemOrex's Avatar
MemOrex
If the cat doesnt need air injection, you will still pass inspection. Does the cat have a port for an air pipe? If not, dont worry about it.
Old Jul 31, 2005 | 04:35 PM
KShep's Avatar
KShep
Memo,
Thanks for the reply. The cat does have an air port, but on the old Y pipe the air pump was plumbed in to a welded pipe about 6" forward fo the cat. Think I should plumb into the cat?
I may try the inspection as is then plumb in if I fail.
Old Jul 31, 2005 | 08:07 PM
MemOrex's Avatar
MemOrex
You can plumb it into the air port or weld it in behind the cat, either way is fine.
