Programming Keyless Entry
Old Jul 30, 2005 | 03:50 PM
mkostas's Avatar
mkostas
Question Programming Keyless Entry
I just purchased a 2000 Ford Excursion Limited 7.3L Diesel. I have one functioning remote. The dealer gave me two unprogrammed remotes and said they could be programmed by assuring all electronic were off and turning on the key 10 times without starting the engine. It is not working. Anyone have and tips?
Old Jul 30, 2005 | 04:54 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around, weekends can be a bit slow however someone will be by to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 30, 2005 | 05:09 PM
4.6Ranger's Avatar
4.6Ranger
keyless entry
You almost had it. Turn the ignition from off to run EIGHT within 10 secs.
the doors will lock and then unlock. press any button on the remote. the doors will lock and unlock again. repeat for the other two remotes. You
to do all three at once. Shut the key off. done
Old Jul 30, 2005 | 05:44 PM
mkostas's Avatar
mkostas
Thanks much. It worked out great.
