My 360 is currently under a rebuild. Soon it willo be a 390 and hopefully it will have more guts than before. My question now is should I keep my holly 500cfm 2 barrel, Or would I really like a 600-650cfm 4 barrel? Mileage isnt going to be really important but I want this truck to move when I am done. I doubt that it will see more that 5500rpm. Unless a 4 barrel is going to give me a huge increase in acceloration I will stay with the 2.
either or but a new carb means new intake which means more cash. I like 4 barrels but i ran my 2 for a long time happily. I gather your mileage will increase with a four and maybe even your throttle reponse, a 600 holley vac secondary....I believe the primaries are small and give nice response. I bet you will be happy with a four and when you do your rebuild you will want it.
It will be a 390 with 360 pistons problaly 30 or 40 over, stock truck 390 heads(rebuilt), headers, the cam is still questionable. I like a little bit of idle lope but I dont want it to be exessive. If I keep the 2 barrel it will just be a stock iron intake. The 2 barrel is new so it should do ok if I use it. If I decide on a 4 barrel, I will buy a dual plane alluminum which would be really nice. Those stock iron intakes are HEAVY. I think since I am used to driving a 91 toyota pickup, this truck will at least seem fast. I hope it turns out alright.
Most people here seem to recomend the Comp 941 cam. for what you are wanting. as for the carb...stick with the 2 barrel and see if you are satisfied. If you find yourself wanting more upper rpm power then try the Edelbrock Performer RPM intake and a 650 or 750 4 barrel.
My 2 cent opinion. If you already have the engine apart, do the intake swap now and go to a 4 barrel carb. Get a dual plane aluminum intake like the Performer RPM from Edelbrock.
I guess, it depends on your budget and how bad you need the truck running.
I run a 2bbl holley on my stock 390 in a '75 highboy with 4.1 gears. She gets up and goes and doesn't look back. The reason I run my 2bbl is the steep grade I live on. I live in the foothills of the Cascades, and I have a problem staying out of the secondaries going up my road, so I figure I'd better run the 2bbl.
I would switch to a 4bbl intake and carb. I did this once if my memory serves me right. Bottom line intake would be an "S". THe rpm would be nice but as kurt has said there is a port mismatch to later stock haeds such as d2 and c8's. I measured the rpm runner exit at 1.99 inches while the head is 1.92-1.93. So, the intake ports of the cylinder heads should be opened up a smudge. I have not seen how placement is. There might be a bigger mismatch than .06-.07 even. I have ported my heads and have the opening to 2.18 in order to accomodate the old intakes.
As for the carb, I noticed a 4bbl wasn't a huge diffrence on bottomend power over a 2bbl but mid and top is a lot better. One other thing to remember is the 2bbl is rated at more iches of mercury than a 4bbl so a 500cfm 4bbl flows more than a 500cfm 2bbl.
I think the crane 343941 is too big for a 4wd or automatic. And since you have stock heads, something like a 343901 or comp equal cam would do. But thats me MR. Small Cam. If you have a 2wd sport truck that will see over 4000rpm then go ahead and run the 941 cam.
You sure about that?
I've seen people corrected for that statement before...
Either way...
I'm running the Holley 500cfm 2bbl and like it just fine.
Throttle response and off idle-low rpm power are great.
If i had the money at the time of the rebuild, I'd have sprung for the 4bbl intake and a 600-650 4bbl carb.
I doubt throttle response or off idle power would be greatly effected, and I cannot help but think running around on small primaries of a 4bbl would be more efficient that running around on the #86 jets my 2bbl requires.
I run the 941 in my motor, with a C6 automatic and the stock torque converter. Good low end torque, great top end power. It works great, and I have no problems recommending it for a motor that has the compression ratio to handle it. Ported heads do help a lot, but they're not absolutely mandatory. There are much bigger cams than the 941...
I wouldn't want to go any bigger than the 941 with the stock torque converter though. The 941 cam turns on about 100rpm after the torque converter stalls. Often times I'll go a few feet, THEN get the burnout.
But yeah, if you're going to be hauling trailers all day, then 901 may be a better choice.
On the carbs: 2 barrel carbs are rated at 3" mercury pressure drop, 4 barrels are rated at 1.5" mercury. So, a 500cfm 2 barrel will flow less than a 500cfm 4 barrel. That's just the way it is. I can site multiple sources...
Edit: On the port mismatch with the RPM intake to the later style port heads (C8's, D2's, etc.) There is quite the mismatch. Hold a gasket up to the intake, align it with the bolt holes, mark the dimensions on the gasket. Then, compare this to the head. You'll see what I mean.
Kurt, I am becoming more convinced every week to opt for something a little bigger than the old 901. I will see how the new motor reacts. I have done a cam change before without moving the engine 1 centimeter why not one more time. Now if i could find a manual 2wd shortbox i would be in heaven and go bigger yet.
Either way...
My .02
First off the 2 barrel is rated at 3"of vacuum and the 4 barrel is rated at 1.5' of vacuum. A Holley engineering tech at a race in Tulsa a million years ago said that a lot of little holes will always give better throttle response than a few big holes. The smaller throttle bores on the 4 barrel primary mean high air velocity thru the venturis which means better throttle response and better atomization of the fuel for better fuel economy than you will get with a 2 barrel. There is a formula for comparing 2V to 4V CFM ratings.
