Need to regear?
Old Jul 27, 2005 | 09:47 PM
04yellowf150's Avatar
04yellowf150
Need to regear?
I have a 4.6L regular cab and I just put a six inch lift on it. I ordered BFG All-terrain 315/70/17s. I was just wondering if i will need to regear and if so what ratio?
Old Jul 27, 2005 | 11:46 PM
wheelerfreak's Avatar
wheelerfreak
what gears do you have now? What size tires came on your truck? That size tires will most likely require a regear, but what ratio depends on what you got now and what you want outta your truck. Lower gears will give better off the line and towing performance at the expense of hwy mileage. It's all a compromise. But if you're lifting your truck and putting much larger tires on it than we can assume your main priority is not fuel mileage. If so 4.11 or 4.56 or so gears will give you better off the line performance, but will make your engine spin faster at hwy speeds and thus decrease mileage.
Old Jul 28, 2005 | 05:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome 04yellowf150, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 28, 2005 | 10:04 AM
ctfordguy's Avatar
ctfordguy
The new tires are about 34.5" (315/25.4*.70+17). You old tires are problably in the 31" range. To maintain the same performance as a 3.55 gear your new gear should be 3.95. If you go with a 4.10 you will have slightly better accel, but you will turn slightly more RPMs(75) on the hwy. To maintain the same performance as a 3.73 gear you new gear sould be a 4.15. The impact now is just the opposite, slightly worse accel, but slightly less RPMs(25) on the hwy.
Either way I would go with the 4.10 unless you are going to be drag racing. If you go with the 4.56 the result is the same no matter what gear you currently have, vastly improved accel and way more RPMs (200-300)on the hwy depending on your original gear.
Old Jul 29, 2005 | 02:45 AM
04yellowf150
Thanks alot for the info. I talked to the technician at 4wheelparts.com and he said to go with the 4.56 gears. I got my tires in today and had them mounted. Noticed a little difference in acceleration but not as much as expected.
Old Jul 30, 2005 | 11:40 AM
one5150fisher's Avatar
one5150fisher
Your tires will be a lot harder to push they will be around 80 lbs each, if you change gears to 4.56 you will need to reprogram to get things right. I have the 5.4, 35's with 4.56 gears and like the power. I turn about 2200 rpms at 75 mph. I think if you go with the 4.10 you will wish you had the 200 rpm difference in power on the highway. I dont see a huge drop in MPG but need some more time to play. The 4.6 likes to wind up I think you will have a lot more fun with the power.
