Oil & Lubrication
2 cycle oil
Old Jul 27, 2005 | 04:58 PM
Avanti's Avatar
Avanti
2 cycle oil
Someone gave me a new unopened bottle of Pennzoil boat motor/ general purpose Premium 2cycle oil.The bottle said it can be used in Weedeaters, outboards, chain saws & any 2 cyle air cooled engine. Can I use it in my Weedeater? My Weedeater says not to use outboard motor oil. Anyone use this gen purpose oil in their Weedeater or Poulan?
Old Jul 27, 2005 | 05:37 PM
racsan's Avatar
racsan
as long as you have the proper mix ratio i doubt you would have any problems, i know there used to be a rating called "TCW" for any water-cooled engine (like a outboard) it stands for two-cycle water cooled. think it has someting to do with ash content, but im no oil expert, just get some on my hands once in a while
Old Jul 27, 2005 | 05:48 PM
jimandmandy's Avatar
jimandmandy
Some engines are more picky about oils than others. I have a weedeater that will immediately foul sparkplugs unless I use the special oil from the lawnmower shop. On the other hand, my gardener uses 76 Custom motor oil from the 99 cent store in his chainsaws with no problem other than a little extra smoke.
Jim
Old Jul 27, 2005 | 09:11 PM
peppy's Avatar
peppy
I am a huge fan of Bel-Ray two stroke products...... but I wouldnt worry about any of the stuff your using. If it worries you....maybe mix it with your normal two stroke oil. Im sure that would displace any concerns of harming your weed eater.
Dont tell anyone, but I actually use a SuperTech product... I use the SuperTech 2 stroke oil for my chain saws.
Old Jul 28, 2005 | 06:45 AM
wavinwayne's Avatar
wavinwayne
I have used the Penzoil 2-stroke oil in my Craftsman chain saw. Worked like a charm.
Old Jul 28, 2005 | 08:07 AM
BrianA's Avatar
BrianA
I have used any, and every, two stroke oil in all manner of two cycle engines.
Never had a problem with any oil in any engine.
There might be a difference in them, but I have never seen it matter in any of my applications.
BTW, I have used Super Tech in both Outboard motor applications and lawn equipment applications. Worked fine for me too.
Old Aug 5, 2005 | 12:56 AM
macktr530's Avatar
macktr530
2 cycle oil
I actually use only husqvarna 2 cycle oil with no problems and it works great
Old Aug 5, 2005 | 07:56 AM
cmlind's Avatar
cmlind
I am picky about 2 cycle oil. I use the OEM just to be sure. Evinrude oil for the boat and stihl oil for the chainsaw. I have had experience with outboard type oils clogging up the muffler in weed eaters. The Pennzoil you have is great for outboards, but I would recommend against it in the weed eater. Small air cooled engines actually like to be run more. If it doesn't get a lot of use all the more reason to use an oil designed specifically for air cooled engines to prevent carbon buildup.
Old Aug 5, 2005 | 02:06 PM
macktr530's Avatar
macktr530
My Grampa used to own a small engine shop and he says that homelite 2 cycle oil was the best but husqvarna is the same. He also taught at the vocational school here and one complete night was on oils and lubrication.
Old Aug 5, 2005 | 02:27 PM
bradcdavis00's Avatar
bradcdavis00
I by the quart bottle of Exxon 2-cycle motor oil and ue it in my chainsaw, weedeater and old LawnBoy 2 cycle lawnmower. They all work fine thank you very much.
