ok everyone, i just ordered a set of the telescoping, heated, power mirrors to replace my stock manual basic mirrors. i was wondering about the heated feature though..... does it turn on by a switch, or is is always on as soon as the truck turns on? thanks !!!
Don't know anout that set of mirrors, but the ones that came with my 04 are turned on by switch. I don't think you would want to leave something like that on all the time.
Can't say about aftermarket mirrors, but the factory ones that Dodge uses is activated by a switch and turns themselves off after so many minutes (or you can manually hit the switch again).
Gotta say, that's the one feature I miss from my Dodge that I wish my Superduty had.
yeah, i will appreciate them up here in alaska.....i will check out the wiring set up when they come in.... but they were fairly in-expensive, so i figured why not. thanks for the info guys !!
That's surprising. I think they are a fairly big draw to be on constantly (mine are fused at 10 amps). Seems a waste, particularly in Houston.
Most every vehicle I have seen has them switched on with the rear defogger. A few have had a separate switch. I think I would put them on a separate switch with a timer if possible.
I agree. If they are supposed to wire directly to always be hot, it shouldn't be a big deal to put a separate switch in line I wouldn't think. No need for them to always be on I wouldn't think.
tawilson1152.... no, i didnt get Ford mirrors..... i bought a set on ebay and paid just over 200 dollars, with the shipping. i really like them though, they are much better than the stock ones i had.
