front axle won't engage
Old 07-26-2005, 10:26 PM
blueoval99's Avatar
blueoval99
blueoval99 is offline
Question front axle won't engage
I've got a 99' f-150 4wd with the vacuum operated hubs at the diff. vacuum pod is mounted on a bracket that allows it to pull on an arm to engage or disengage the front axle. I got under the truck and had my wife operate the switch and it's trying to engage it but no go, any help with this out there?
Old 07-27-2005, 01:02 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Hi and welcome to the forum
If you help move the lever will it engage?
If not then you might have low vacuum getting to it possibly due to a cracked vacuum line etc.
If the lever moves but it still doesn't engage then you may have a shift fork problem in the diff. I've replaced quite a few of them.
If you do a search in here you should find quite a bit of info in the problem.
Old 07-27-2005, 01:28 AM
cleevesj's Avatar
cleevesj
cleevesj is offline
Hi Blue oval, Here is a link to a simple problem I had. It shows the inside of the axle at the point of the vacuum switch. The front axles need to be turning to fully engage the front end as the gear inside the vacuum switch must slide ever to engage the differential and the passenger side axle.<a href="https://www.ford-trucks.com/forums/archive/index.php/t-379249-Help%21%2097%27%20front%20axle%20problem.">Help! 97' front axle problem.</a> This should link for you, but if not just cut and paste. let me know if you can get to it or not and I will copy the pic and send it to you.
Old 07-27-2005, 08:01 AM
blueoval99's Avatar
blueoval99
axle
it won't go moving or not, i think it's the fork or the coupler itself is damaged, thank's for the info.
Old 07-27-2005, 12:33 PM
cleevesj's Avatar
cleevesj
cleevesj is offline
These front ends come out very easy also. Just unbolt the cv shafts and there are three other bolts and the drive shaft and the center section comes out very easy. Take the front diff. cover off and the axle is held in with a c clip. Slide the axle out and then you have access to the vacuum switch. I put the gear in backwards when putting in new gears and had to pull the front end back out to flip the gear in the vacuum switch and it only took about a hour to an hour and a half and was back on the road. Good Luck!
Old 07-27-2005, 01:39 PM
lancekilgore's Avatar
lancekilgore
lancekilgore is offline
how often should you have to replace the gears or how often do they go out. or does it depend on how often you use the 4X4 and how much abuse you give them off road?
Lance
Old 07-27-2005, 01:49 PM
cleevesj's Avatar
cleevesj
cleevesj is offline
I have not blown a gear yet. I have blown up a CV though(Mud Bog). Nice thing about these front ends, they are easy to work on. Not the stongest, but easy to work on. I am running 4.56 gears in mine and no troubles so far. 140,000 miles.
bkuuz1
1997-2006 Expedition & Navigator
09-20-2014 10:21 AM
mikecyr
2004 - 2008 F150
12-07-2013 06:25 PM
boggin150
15
10-09-2009 03:09 PM
arffdog
2004 - 2008 F150
05-01-2008 05:31 PM
truckmonger1
1997 - 2003 F150
10-30-2007 09:21 PM
Quick Reply: front axle won't engage
