short in wire....speedometer problem
Old Jul 26, 2005 | 03:19 PM
jessfactor's Avatar
jessfactor
95 F150 I6 2wd M5OD
A few weeks ago I began having a problem w/my speedometer jumping around. Whenever the needle would jump around the truck would also buck. Another interesting observation is that, even in neutral, if the truck began to coast at low speeds the truck would stall, even moving from a dead stop on a hill. Because it was in neutral I knew the problem had to be electrical.
I originally posted this in the electrical forum, but through the course of the day it only received 6 views and no responses.
I unplugged the ABS sensor, where the truck gets the speedometer reading and that fixed the bucking and stalling, but now I have no speedometer and naturally my odometer reading doesn't move. After running diagnostics on it I narrowed it down to a short in a wire, I'm assuming one of the wires that runs from the ABS sensor to the ignition control modual. I now have three questions.
1. Has anybody ever experienced a problem like this?
2. How do you test the wire to find which one is bad?
3. Where can I located the correct color coded replacement wires so that I can use the manual for future repairs.
Other than this problem the truck runs perfectly.
Old Jul 26, 2005 | 03:23 PM
andym's Avatar
andym
The truck doesn't get the speedometer reading from the ABS sensor, it gets it from the VSS (vehicle speed sensor). That's what you unplugged. It's basically a magnet that is so simplistic it never fails. Take it out and clean it off with a rag. If that doesn't fix the problem, it's most like the speedo unit in the gauge cluster.
Do a search on this, it's been covered a lot in this forum.
Old Jul 26, 2005 | 06:03 PM
alz's Avatar
alz
search bad PSOM
Old Jul 26, 2005 | 09:57 PM
jessfactor's Avatar
jessfactor
That little magnet is the ABS sensor and that is also where the truck gets the speedometer reading. I forgot to mention that I replaced that (thats how I found out it was the ABS sensor). I also cleaned out the differential to make sure there were no broken teeth that were throwing off the magnet. Everything looked good inside the differential. Thats why I'm pretty sure its a bad wire somewhere, but I'm still open to ideas because I have no idea how to find where the wire is bad.
As far as the speedometer unit in the guage cluster: Would that actually make the truck studder and stall? Also, Can I replace the speedo part and keep my current odometer? Thanks alot for the reply.
